cashpoint Posted March 15, 2011 Share Posted March 15, 2011 Trying to get the site to site VPN to come up between 2 ASA 5510. Runing in a lab enviroment using as 2600 router as router on a stick to let the 2 ASA's communicate but only have CCNA and stuck. Used the VPN wizard failed so reloaded and tried the CLI from info gleamed form the web but the tunnels isn't there and don't know how to trouble shoot the problem can anyone help? Quote Link to comment Share on other sites More sharing options...
neo2810 Posted March 15, 2011 Share Posted March 15, 2011 PM me the config on the devices and a basic diagram of the setup you want (with your ip scheme) and I'll take a look. Quote Link to comment Share on other sites More sharing options...
cashpoint Posted March 16, 2011 Author Share Posted March 16, 2011 Pm sent Quote Link to comment Share on other sites More sharing options...
Ric Posted March 16, 2011 Share Posted March 16, 2011 does it require any licences? Quote Link to comment Share on other sites More sharing options...
cashpoint Posted March 16, 2011 Author Share Posted March 16, 2011 I don't belive so show version gives below the other ASA gives the same Really am fcuked Cisco Adaptive Security Appliance Software Version 8.2(1) Device Manager Version 6.2(1) Compiled on Tue 05-May-09 22:45 by builders System image file is "disk0:/asa821-k8.bin" Config file at boot was "startup-config" IRHH-U3A up 1 hour 59 mins Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz Internal ATA Compact Flash, 256MB BIOS Flash Firmware Hub @ 0xffe00000, 1024KB Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0) Boot microcode : CN1000-MC-BOOT-2.00 SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03 IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04 0: Ext: Ethernet0/0 : address is e05f.b92d.f848, irq 9 1: Ext: Ethernet0/1 : address is e05f.b92d.f849, irq 9 2: Ext: Ethernet0/2 : address is e05f.b92d.f84a, irq 9 3: Ext: Ethernet0/3 : address is e05f.b92d.f84b, irq 9 4: Ext: Management0/0 : address is e05f.b92d.f84c, irq 11 5: Int: Not used : irq 11 6: Int: Not used : irq 5 Licensed features for this platform: Maximum Physical Interfaces : Unlimited Maximum VLANs : 100 Inside Hosts : Unlimited Failover : Active/Active VPN-DES : Enabled VPN-3DES-AES : Enabled Security Contexts : 2 GTP/GPRS : Disabled SSL VPN Peers : 2 Total VPN Peers : 250 Shared License : Disabled AnyConnect for Mobile : Disabled AnyConnect for Linksys phone : Disabled AnyConnect Essentials : Disabled Advanced Endpoint Assessment : Disabled UC Phone Proxy Sessions : 2 Total UC Proxy Sessions : 2 Botnet Traffic Filter : Disabled This platform has an ASA 5510 Security Plus license. Serial Number: ******** Running Activation Key: ********************* Configuration register is 0x1 Configuration has not been modified since last system restart. Quote Link to comment Share on other sites More sharing options...
cashpoint Posted March 16, 2011 Author Share Posted March 16, 2011 Solved this now. I'd been using the correct config but I was expecting the VPN to come up as soon as I'd complete the configuration of it. So once I'd done it I sat and waited for the tunnel to spring into life......... but it never did. Now i know data has to be passed for the tunnel to come up. Only realised this after 10 hours of trying to find a solution. Quote Link to comment Share on other sites More sharing options...
neo2810 Posted March 17, 2011 Share Posted March 17, 2011 Ah, ignore my PM then. Simple error to make if you've not set a VPN up before. Don't be too hard on yourself Quote Link to comment Share on other sites More sharing options...
