KrisM Posted March 15, 2011 Share Posted March 15, 2011 Hi all, I have an Apexi water temp sender i need to fit. It is M12x1.25 in size. I ordered an inline aluminum adapter but it is a 1/8npt female thread. I think they are too close in size to retap unless someone knows different. Anyone know where i can get a suitable M12 adapter? Thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted March 15, 2011 Share Posted March 15, 2011 Hi all, I have an Apexi water temp sender i need to fit. It is M12x1.25 in size. I ordered an inline aluminum adapter but it is a 1/8npt female thread. I think they are too close in size to retap unless someone knows different. Anyone know where i can get a suitable M12 adapter? Thanks Would probably be easier to get a 1/8npt temperature sender to be honest. What about welding up the 1/8npt hole and drilling tapping a M12 hole? Quote Link to comment Share on other sites More sharing options...
Nic Posted March 15, 2011 Share Posted March 15, 2011 16401634 GReddy Sensor Adapter http://www.trust-power.com/03electric/img/hose_atach.jpg 13911250 GReddy Aluminium Radiator Pipe - 2JZGTE 13911251 GReddy Aluminium Radiator Pipe - 2JZGTE VVTi http://www.trust-power.com/03electric/img/radi_pipe.jpg Quote Link to comment Share on other sites More sharing options...
KrisM Posted March 15, 2011 Author Share Posted March 15, 2011 Thanks both. I was considering using a 1/8 blank and drilling and tapping a new hole in what i have Scott. Will any temp sensor do the same job? Cheers Nic, appreciated. That looks expensive kit Quote Link to comment Share on other sites More sharing options...
Scott Posted March 15, 2011 Share Posted March 15, 2011 Thanks both. I was considering using a 1/8 blank and drilling and tapping a new hole in what i have Scott. Will any temp sensor do the same job? Cheers Nic, appreciated. That looks expensive kit As long as it is the same spec then yes. You could go down the blank route but that would then open up potential issues. Best to weld it and then re-tap it. Is the adapter stainless? Might need to look around a wee bit for stainless welders local to you. Quote Link to comment Share on other sites More sharing options...
KrisM Posted March 15, 2011 Author Share Posted March 15, 2011 Its aluminium. If i bunged it then i would use a liquid weld of some sort on the threads. I am concious it is on the bottom radiator hose so no cost cutting here really, could end in disaster. Quote Link to comment Share on other sites More sharing options...
