Ibrar Jabbar Posted March 22, 2012 Author Share Posted March 22, 2012 A lovely Job of welding Ibrar? that welding looks BLOODY INSANE. Like it came from Hypertune that way. Very good Props to that guy... Yes the welding is identical, you could never tell it's been tampered with Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 23, 2012 Share Posted March 23, 2012 Is your welder a robot by any chance?? Thats top draw... Car is coming along sweet! Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted March 23, 2012 Share Posted March 23, 2012 This build is just unbelievable! What a car! The welding is phenomenal Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 23, 2012 Share Posted March 23, 2012 I think they will need to revisit the definition of Awesome! Quote Link to comment Share on other sites More sharing options...
hodge Posted March 23, 2012 Share Posted March 23, 2012 I'm pleased you decided to weld the flange on instead of making an adaptor plate, it loos so much more neat. Have you sized up the TB against the flange while it's all in place. The finger/motor on the TB is very large. I had to make a small hole in Johnny's chassis leg to slip the end of the motor into so it would all fit nice and tidy. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 23, 2012 Share Posted March 23, 2012 I'm pleased you decided to weld the flange on instead of making an adaptor plate, it loos so much more neat. Have you sized up the TB against the flange while it's all in place. The finger/motor on the TB is very large. I had to make a small hole in Johnny's chassis leg to slip the end of the motor into so it would all fit nice and tidy. Love when you talk Dirty John It sounds so provocative Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 23, 2012 Author Share Posted March 23, 2012 Is your welder a robot by any chance?? Thats top draw... Car is coming along sweet! He walks like a robot, so there may be some connection there This build is just unbelievable! What a car! The welding is phenomenal Thanks, It's coming along nicely I think they will need to revisit the definition of Awesome! LOL, thanks I'm pleased you decided to weld the flange on instead of making an adaptor plate, it loos so much more neat. Have you sized up the TB against the flange while it's all in place. The finger/motor on the TB is very large. I had to make a small hole in Johnny's chassis leg to slip the end of the motor into so it would all fit nice and tidy. It wasn't easy chopping up a 2K manifold, but had to be done. There's plenty of clearance as I measured up about 20 times. I may mount it tonight and post pics later. Quote Link to comment Share on other sites More sharing options...
supradibbs Posted March 24, 2012 Share Posted March 24, 2012 Sorry if this has already been covered why the vette TB, something to do with the ECU? Quote Link to comment Share on other sites More sharing options...
baldy Posted March 24, 2012 Share Posted March 24, 2012 im loving the workmanship in this build, are you going to remove the throttle cable bracket thats not being used now:eyebrows: Quote Link to comment Share on other sites More sharing options...
Mike B Posted March 24, 2012 Share Posted March 24, 2012 Wow, just stumbled on this... A piece of art! Well done, so impressed.. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 24, 2012 Author Share Posted March 24, 2012 (edited) Gave the gearbox a good degreasing and painted it in 2K satin black. Fitted the RPS carbon billet clutch and put the gearbox back where it belongs. Also fitted the manifold and TB. Edited March 24, 2012 by Ibrar Jabbar (see edit history) Quote Link to comment Share on other sites More sharing options...
lexmk4 Posted March 24, 2012 Share Posted March 24, 2012 awesome!!!! Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 24, 2012 Author Share Posted March 24, 2012 Sorry if this has already been covered why the vette TB, something to do with the ECU? JohnnyG done the research into fitting a TB with true DBW to an aftermarket manifold. The Vette TB was chosen and worked great, so I'm going with Johnny's idea as advised by The Hodge im loving the workmanship in this build, are you going to remove the throttle cable bracket thats not being used now:eyebrows: Thanks baldy, the bracket is staying It would be a mess if I attempted to remove it. Wow, just stumbled on this... A piece of art! Well done, so impressed.. Thanks Mike Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted March 24, 2012 Share Posted March 24, 2012 looking awsome ibrar Quote Link to comment Share on other sites More sharing options...
Bailey. Posted March 24, 2012 Share Posted March 24, 2012 IBrah, this car rocks mate, it's a real work of art, even down to the gear box paint job, its stunning! Have you thought about venting the rockers under the car so the pipes are all but not seen? And is the black Water pipe at the rear of the bay going to be tucked away behind the motor when she is all complete? Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 24, 2012 Author Share Posted March 24, 2012 (edited) awesome!!!! looking awsome ibrar IBrah, this car rocks mate, it's a real work of art, even down to the gear box paint job, its stunning! Have you thought about venting the rockers under the car so the pipes are all but not seen? And is the black Water pipe at the rear of the bay going to be tucked away behind the motor when she is all complete? Thanks, I prefer the pipes as they are, as I'm not really into hiding everything. None of the hoses have been fixed into place yet, but will be tidied up at a later stage. Edited April 10, 2012 by Ibrar Jabbar (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted March 25, 2012 Share Posted March 25, 2012 is the being poster on Supraforums? When do you think it will be complete? Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 25, 2012 Author Share Posted March 25, 2012 is the being poster on Supraforums? When do you think it will be complete? Not posted the build on Supraforums, I may do when I get time. I was hoping end of March but looks like it will be end of April now. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted March 25, 2012 Share Posted March 25, 2012 It just gets better and better Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 25, 2012 Share Posted March 25, 2012 I wish i had the equipment and ability to do this for my car, this has to be the most thorough project i have seen, brilliant stuff mate Quote Link to comment Share on other sites More sharing options...
AndyT Posted March 25, 2012 Share Posted March 25, 2012 It's an epic effort Ibrar. One of my favourite reads. Well done and I'm looking forward to the finish. Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted March 25, 2012 Share Posted March 25, 2012 The best overhaul I have ever come across! Fantastic job Ibrar! Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 25, 2012 Author Share Posted March 25, 2012 It just gets better and better I wish i had the equipment and ability to do this for my car, this has to be the most thorough project i have seen, brilliant stuff mate It's an epic effort Ibrar. One of my favourite reads. Well done and I'm looking forward to the finish. The best overhaul I have ever come across! Fantastic job Ibrar! Thank you guys Quote Link to comment Share on other sites More sharing options...
Matt H Posted March 26, 2012 Share Posted March 26, 2012 (edited) Fantastic detail Quick question; the red highlighting of 'Getrag' on the box looks impeccable, how did you achieve this? I want the 'APR Racing' on my brake calipers doing in a similar fashion but the first painter I asked said it would be too tricky? Edited March 26, 2012 by Matt H (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 26, 2012 Share Posted March 26, 2012 Just get a stencil made by a sticker company Quote Link to comment Share on other sites More sharing options...
