Biguns Posted March 13, 2011 Share Posted March 13, 2011 As above but what bits do I need to buy to put it right? Thx in advance Quote Link to comment Share on other sites More sharing options...
keron Posted March 13, 2011 Share Posted March 13, 2011 Should never wash the engines as the water gets into the connectrs of the electrical plugs and more so...on the na, the water travels down all the 6 spark plug chambers and causes the mis...so take all the plug leads out and try get the water out...you shouldn't need any parts tbh... Quote Link to comment Share on other sites More sharing options...
RobUK Posted March 13, 2011 Share Posted March 13, 2011 A TT engine should do it Depends what you have washed, and what problems you are having... Have you tried drying off the engine? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted March 13, 2011 Share Posted March 13, 2011 get the vacum out and suck the water out from around the plugs,take the dizzy cap off and all the leads and get busy with the hair dryer take the connector off the ignitor aswell. Quote Link to comment Share on other sites More sharing options...
Josh Posted March 13, 2011 Share Posted March 13, 2011 If your neighbour sets fire to your car, that'd dry it out I washed my engine today but used a damp/nearly dry sponge to do it. Only really washed the painted parts of the bay and wiped over the dirty parts. Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 13, 2011 Author Share Posted March 13, 2011 If your neighbour sets fire to your car, that'd dry it out I washed my engine today but used a damp/nearly dry sponge to do it. Only really washed the painted parts of the bay and wiped over the dirty parts. I used a power washer damn retard that I am Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted March 13, 2011 Share Posted March 13, 2011 I used a power washer damn retard that I am Eeeawwww eeeaawwww Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 13, 2011 Author Share Posted March 13, 2011 Any guides on what to remove to replace plugs? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted March 13, 2011 Share Posted March 13, 2011 (edited) you need to undo the throttle body and slide it forward a bit.plus remove the plastic covers front and back.there 4 bolts holding the throttlebody to the y piece and 2 nuts holding the supporting bracket under the front of the throttle body.Also make sure you disconnect any wires that could be pulled on and the water pipe going to the throttle body. Edited March 13, 2011 by barneybrendan (see edit history) Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted March 13, 2011 Share Posted March 13, 2011 ive done this when i first got mine thing is i was at the petrol station using there jet washer, she sounded like a wrx sti! i didnt want to driver her home which was only 2 mile away so i used the petrol stations hova and had to get my brother to drop my tools off and remove the plastics to suck the water from around the plugs worked tho.. haha Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 14, 2011 Share Posted March 14, 2011 get the vacum out and suck the water out from around the plugs,take the dizzy cap off and all the leads and get busy with the hair dryer take the connector off the ignitor aswell. Just be careful if you're using your mums best vacuum cleaner, most don't like a drink, especially if the bag/chamber is already full Quote Link to comment Share on other sites More sharing options...
Havard Posted March 14, 2011 Share Posted March 14, 2011 you'll need a 12mm extended socket to get the throttle body off Andy. Remove the air filter housing and pipework first and then start on the throttle body. It's actually quite simple once you get into it but the sign of massive amounts of parts and bolts building up is a bit daunting..!! You then need to get the spark plug cover off and you will see the recesses where the plugs are. I would get an air line or a can of compressed air from Tescos and blow the water out of the plug gaps. Then take it for a long run..!! H. Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 14, 2011 Author Share Posted March 14, 2011 Boltsthx H i have removed all the intake stuff and the bracket under the throttle body and the two bolts going through the top of the body but can't see the other two bolts Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted March 14, 2011 Share Posted March 14, 2011 i will take a couple pics tomorrow for you . Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 14, 2011 Author Share Posted March 14, 2011 Thx bud really appreciate it Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 14, 2011 Share Posted March 14, 2011 If the engine was running ok before you washed it, I'd throw some dirt on it and see if that cured the misfire. Makes sense, doesn't it? Quote Link to comment Share on other sites More sharing options...
Havard Posted March 14, 2011 Share Posted March 14, 2011 Boltsthx H i have removed all the intake stuff and the bracket under the throttle body and the two bolts going through the top of the body but can't see the other two bolts They are underneath if memory serves. You'll need an extended socket to get to them. Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 15, 2011 Author Share Posted March 15, 2011 Pics would be nice if anyone has em Quote Link to comment Share on other sites More sharing options...
Havard Posted March 15, 2011 Share Posted March 15, 2011 Pics would be nice if anyone has em I would take some but I no longer have an NA..!! Quote Link to comment Share on other sites More sharing options...
nevins Posted March 15, 2011 Share Posted March 15, 2011 As said above dry up any standing water in the plug recess's and then go crazy with some wd40 on all the connections with multi plugs. Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 15, 2011 Author Share Posted March 15, 2011 found the bolts now and dried up as much water as possible , will try start it again tomorrow :-( Quote Link to comment Share on other sites More sharing options...
Purity14 Posted March 16, 2011 Share Posted March 16, 2011 I jetwashed my PC and it wont turn on, what do? Quote Link to comment Share on other sites More sharing options...
mr lover Posted March 16, 2011 Share Posted March 16, 2011 I jetwashed my PC and it wont turn on, what do? Stop w@nking over it and you won't need to clean it, HTH Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 16, 2011 Author Share Posted March 16, 2011 Lol ^^^^^^ Well I've changed the plugs,dizzy cap and rotor arm and it seems to be running on five so gonna change the HT leads tomorrow :-( Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 17, 2011 Author Share Posted March 17, 2011 woohoo fixed it all by myself lol. only cost me a set of plugs,rotor arm,dizzy cap and ht leads Quote Link to comment Share on other sites More sharing options...
