Josh Posted March 12, 2011 Share Posted March 12, 2011 My driver's side window has a small gap between it and the seal which causes a whistling sound when going over 80 leptons. I've got the door card off as I remember someone saying you can adjust the glass. Can anyone tell me how to do this, please? Thanks Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted March 12, 2011 Share Posted March 12, 2011 If its the height your talking about then there will be two small bump stops at the top of each door. They stop the window going too high. They are accessed through holes at the top inside part of the door. If my memory serves me correctly they might have sticky labels over them, so these will need to be peeled off first. The tilt of the window can be adjusted by rotating a handle near the bottom of the door. Again if my memory serves me correctly this is the only knob you can turn on the door. Obviously turn it one way for out and the other for in, its not rocket science Quote Link to comment Share on other sites More sharing options...
Josh Posted March 12, 2011 Author Share Posted March 12, 2011 If its the height your talking about then there will be two small bump stops at the top of each door. They stop the window going too high. They are accessed through holes at the top inside part of the door. If my memory serves me correctly they might have sticky labels over them, so these will need to be peeled off first. The tilt of the window can be adjusted by rotating a handle near the bottom of the door. Again if my memory serves me correctly this is the only knob you can turn on the door. Obviously turn it one way for out and the other for in, its not rocket science Cool thank you There's a big plastic sheet covering the inside of the door so I guess I'll have to remove that first, or at least peel it away at the top. I'll have a go then let you know. Cheers! Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted March 12, 2011 Share Posted March 12, 2011 Cool thank you There's a big plastic sheet covering the inside of the door so I guess I'll have to remove that first, or at least peel it away at the top. I'll have a go then let you know. Cheers! Not sure you have to remove this. The lower knob should be visible and the upper stoppers are enclosed behind their own seals because they are not covered by the big plastic moisture seal. Will see if I can find a picture. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted March 12, 2011 Share Posted March 12, 2011 Borrowed from Matt H's speaker install. You can see the tilt adjuster at the bottom of the door. Its the bot below the handle with the long metal strip. Its outside the moisture barrier as I can see the mastic line where it use to be. The white coloured knob on the left side is the thing you need to adjust for the tilt. I think you might also have to undo the screw in the middle of the plate to do this then tighten it up afterwards. As for the two window height adjusters I can see that they are indeed behind the moisture barrier. You can see the bolt for one inside a hole above the speaker bracket. I would think its the tilt you need to adjust not the height, as over time the rubber looses is flex and becomes compressed and hence the road noise and slight leaking. Quote Link to comment Share on other sites More sharing options...
Josh Posted March 12, 2011 Author Share Posted March 12, 2011 Thank you very much, very helpful. Managed to just move the front bump stop up and it's now sealing correctly. Thanks for your help. Now to go for a drive to make sure it's sorted Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted March 12, 2011 Share Posted March 12, 2011 Thank you very much, very helpful. Managed to just move the front bump stop up and it's now sealing correctly. Thanks for your help. Now to go for a drive to make sure it's sorted No problem mate. I have just commented on your air con issue too. Quote Link to comment Share on other sites More sharing options...
