colsoop Posted March 11, 2011 Share Posted March 11, 2011 Callling on you knowledgable people can you look at the attached diagram and tell me if this is ok. Im not a plumber so want to continue with the speedfit (there from the previous bathroom) and flexible compression pipes for ease of install. The thermostat will mount to the wall, and it is a concealed unit. I believe the water is high pressure (although the mixer works with both)and its a combi boiler. The thermostat is a one way type. Thanks for your time Quote Link to comment Share on other sites More sharing options...
Havard Posted March 11, 2011 Share Posted March 11, 2011 What is the flowrate of the shower? The drawing looks ok but I wonder if the pipework is a bit small for a high flow shower? H. Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 11, 2011 Author Share Posted March 11, 2011 This is the shower i have: HERE I believe the system is designed to work with low and hi pressure. Quote Link to comment Share on other sites More sharing options...
edge Posted March 11, 2011 Share Posted March 11, 2011 Your mixer shower will say in the book somewhere that it will need to have balanced water supplies (same flow and pressure) as you may have Higher flow from the cold than the hot as the hot side will be lower than the cold, this causes a limited temperature range in the shower and you may not even get it warm enough if your pressure and flow are greater on the cold. So try a flow limiter on the cold side if you cant get it hot enough. Make sure you connect them to the correct inlets as its a thermostatic shower. It uses a ceramic flow control so make sure you flush the pipe well because if you get some small hard debris on the ceramic plates they scratch and you will have a drip. Quote Link to comment Share on other sites More sharing options...
merckx Posted March 11, 2011 Share Posted March 11, 2011 Best to use "full bore" isolation valves as the standard ones will reduce the flow rate. I don't think you can get them in the speedfit plastic fittings, only brass with compression fittings as far as I'm aware. Quote Link to comment Share on other sites More sharing options...
