seba Posted March 11, 2011 Share Posted March 11, 2011 (edited) To make a long story short, my supra is going to the garage next week blablabla blabliblu Do the Soarer arms, wishbones, wheel hub etc all fit the Supra? Have damage on the car and someone offered to give(sell) these from a Soarer. I still don't know whats actually wrong because i can't get a good look at it and the wheel is so bend that i can't even take it of. Thx Edited March 11, 2011 by seba (see edit history) Quote Link to comment Share on other sites More sharing options...
mobius Posted March 11, 2011 Share Posted March 11, 2011 both share lots of components also try asking on soarer world forum Quote Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted March 11, 2011 Share Posted March 11, 2011 (edited) Depending on the year almost all are the same. The front is the rear has a different subframe and arb mount. If you want to use the Soarer stuff you will need to use the Soarer rear subframe. Basically the subframe on a Sup hangs out wider meaning the lenght of the arms is shorter, on a Soarer they are longer with a less wide subframe. The frames themselves are totally swapable, you just need to change the hand break cables. Edited March 11, 2011 by Andy-No-Knee (see edit history) Quote Link to comment Share on other sites More sharing options...
seba Posted March 12, 2011 Author Share Posted March 12, 2011 Depending on the year almost all are the same. The front is the rear has a different subframe and arb mount. If you want to use the Soarer stuff you will need to use the Soarer rear subframe. Basically the subframe on a Sup hangs out wider meaning the lenght of the arms is shorter, on a Soarer they are longer with a less wide subframe. The frames themselves are totally swapable, you just need to change the hand break cables. So i can use any part from the front without problems? I think the rear only needs the hub replaced but not sure. But the rearparts can never fit the Supra without swapping the entire Soarer subframe? If this is correct i'd better have a look out for some replacementparts if needed, don't want any unnecesary costs. Quote Link to comment Share on other sites More sharing options...
