Parry_10 Posted March 10, 2011 Share Posted March 10, 2011 O2 sensor for tt £140inc vat from toyota with 10% discount, anybody know of anywhere you can get one for cheaper? Or does anyone have a good used one failing that cheers Quote Link to comment Share on other sites More sharing options...
Kirk Posted March 10, 2011 Share Posted March 10, 2011 You can get denso o2 sensors off ebay for half the price. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 10, 2011 Share Posted March 10, 2011 but nobody has managed to confirm the correct Denso part number for a J-spec car yet. Quote Link to comment Share on other sites More sharing options...
Kilps Posted March 10, 2011 Share Posted March 10, 2011 I'm after one of these. Just a single one for a JSpec TT. I think a few people are. Is it worth trying to sort out a group buy? Either from a local Mr T, Steve Manley or whoever else can supply them? Not sure what sort of interest there would be though..? Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted March 10, 2011 Author Share Posted March 10, 2011 Thats a great idea mate im sure there would be more than enough interest in a group buy Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 10, 2011 Share Posted March 10, 2011 Just get a universal one, as long as it has the correct number of wires and the right fitting, thats all you need. Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted March 10, 2011 Share Posted March 10, 2011 Just get a universal one, as long as it has the correct number of wires and the right fitting, thats all you need. Know of any? Or got a link? Quote Link to comment Share on other sites More sharing options...
Tyson Posted March 10, 2011 Share Posted March 10, 2011 Just get a universal one, as long as it has the correct number of wires and the right fitting, thats all you need. I have heard many a horror story about universal ones on other forums. IMO you would be better off in the long run getting a genuine one. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted March 10, 2011 Author Share Posted March 10, 2011 Yeh both ryan and lee p advised me to only go for a genuine one when ryan had my car on the dyno the other day so im going to stick with genuine Quote Link to comment Share on other sites More sharing options...
djg99 Posted March 10, 2011 Share Posted March 10, 2011 You got a part number as the mr t near me is cheap :-) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 10, 2011 Share Posted March 10, 2011 (edited) Know of any? Or got a link? I have heard many a horror story about universal ones on other forums. IMO you would be better off in the long run getting a genuine one. Don't know where all this horror story rubbish comes from, the way an NB O2 sensor works is just the same for all (discounting Titania and resistance type) if they fail all that happens is that you run rich as default and get a CEL, they are only use during closed loop non boost. As long as it has the right number of heater wires, it fine, they are all made the same way, and you will probably find that they are also made by the major manufactures on the same production lines, just unbranded or for brand. http://www.ecolambda.co.uk/main/muniversal.htm You will probably find several of the Toyota application ones have the same number of wires, also check the heater resistance, and the same boss fittings. STD Denso sensor. http://www.worldcarparts.co.uk/CarParts/tabid/144/ProductID/1578/Default.aspx Edited March 12, 2011 by Tricky-Ricky (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted March 10, 2011 Share Posted March 10, 2011 You got a part number as the mr t near me is cheap :-) 89465-19635 Oxygen Sensor - J-spec TT 89465-19725 Oxygen Sensor - J-spec TT VVTi 89465-19605 Oxygen Sensor - Front - UK Spec 89465-19595 Oxygen Sensor - Rear - UK Spec 89465-19615 Oxygen Sensor - NA x 2 Quote Link to comment Share on other sites More sharing options...
p3te Posted March 10, 2011 Share Posted March 10, 2011 im also after a new one for a J spec TT STD Denso sensor. http://www.worldcarparts.co.uk/CarParts/tabid/144/ProductID/1578/Default.aspx The link you give here http://www.worldcarparts.co.uk/Default.aspx?TabId=144&ProductID=1578 the part number matches the one nic give for a UK spec rear sensor, what’s the difference between the 2 if any? I’ve also seen the denso ones on eBay but not sure what model they are for Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 10, 2011 Share Posted March 10, 2011 Know of any? Or got a link? I have heard many a horror story about universal ones on other forums. IMO you would be better off in the long run getting a genuine one. im also after a new one for a J spec TT e The link you give here http://www.worldcarparts.co.uk/Default.aspx?TabId=144&ProductID=1578 the part number matches the one nic give for a UK spec rear sensor, what’s the difference between the 2 if any? I’ve also seen the denso ones on eBay but not sure what model they are for UK and JDM first sensor should be thsame, but i am not sure about the second. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 11, 2011 Share Posted March 11, 2011 What exactly is in an o2 sensor and why can't it just be cleaned to work as god as new? I know lemon juice works a bit, so is there something that works a lot? Some other kind of acid maybe? Quote Link to comment Share on other sites More sharing options...
Nic Posted March 11, 2011 Share Posted March 11, 2011 (edited) What exactly is in an o2 sensor and why can't it just be cleaned to work as god as new? I know lemon juice works a bit, so is there something that works a lot? Some other kind of acid maybe? Oxygen sensors have a limited life of around 30K-50K miles, lemon juice can help remove carbon deposits which *may* make a short term difference, but once they have worn out then they need replacing. http://www.mkivsupra.net/vbb/showthread.php?35940-Narrowband-O2-Sensor http://www.picoauto.com/applications/lambda-sensor.html Edited March 11, 2011 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 11, 2011 Share Posted March 11, 2011 so, is the first UK spec the correct one for a J-spec? Because if it is... http://cgi.ebay.co.uk/FRONT-LAMBDA-SENSOR-TOYOTA-SUPRA-NATO-3-0-2JZGTE-93-99-/330468667330?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf177afc2 £60 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 12, 2011 Share Posted March 12, 2011 1/2 that price from sparkplugs.co.uk but I would fit a genuine one if you want total peace of mind, a lot of generic ones fail to perform like an OE part, in my experience. Quote Link to comment Share on other sites More sharing options...
Kilps Posted March 12, 2011 Share Posted March 12, 2011 ... Quote Link to comment Share on other sites More sharing options...
Dazzi Posted March 12, 2011 Share Posted March 12, 2011 i got a universal single wire one for 15 quid and does the job good, took my fuel economy from 280 to 350 miles per tank Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted March 12, 2011 Author Share Posted March 12, 2011 Where from mate? And was it direct fit? Maybe worth a try for 15quid Quote Link to comment Share on other sites More sharing options...
Keefred Posted March 12, 2011 Share Posted March 12, 2011 I have spent hours looking for these, that Dox 0110 one on e bay is a universal one, I only found these ones 2009 Denso book, according to that the only 2 listed are. 89465-19605 = Dox-0228 89465-19595 = Dox-0227 The Dox-0110 seems to be a universal one as it says it fits a supra (nato) 3.0 and Carina e, celica, Rav 4 etc Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 13, 2011 Share Posted March 13, 2011 (edited) I got the Denso Dox-0228 for Jspec from sparkplugs.co.uk ; its for the Supra, same plug , same sensor no difference to toyota denso Senor jst the over inflated price toyota charge Guys just got back off Ebay: Part Number is dox-228. but looking online http://www.sparkplugs.co.uk/pages/database/plug-detail-ccp.asp?partno=DOX-0228 They do it for 58 rather than 89 pound http://www.sparkplugs.co.uk/graphics/images/Denso-Lambda/photos/ImageA/DOX-0228.jpg http://www.sparkplugs.co.uk/graphics/images/Denso-Lambda/photos/ImageB/DOX-0228.jpg http://www.sparkplugs.co.uk/graphics/images/Denso-Lambda/photos/ImageC/DOX-0228.jpg Make TOYOTA Model Supra (Nato) Engine Size 3L Production (Month/Year) 05/1993 -> 10/1999 Engine Code 2JZGTE Engine Power (KW) 243 Important info N/A Vehicle Manufacturer OE Part number TOYOTA 8946519605 TOYOTA 8946549045 FRONT Sensor: DOX-0228 REAR Sensor: DOX-0227 Edited March 13, 2011 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted March 13, 2011 Share Posted March 13, 2011 Thanks for posting that up Jellybean Quote Link to comment Share on other sites More sharing options...
aman00123 Posted March 13, 2011 Share Posted March 13, 2011 Cheers Jellybean, but what the OP (and a few others I think) wanted to know is, do any of those sensors work in a J-Spec TT? If so which one, the front or the rear? They are pretty easy to find, I think I found them at around £35ish, but they dont have the same part number as the J-Spec TT's... Quote Link to comment Share on other sites More sharing options...
