Oil cooler fitting(stock cooler removal)
Bailey.
The neat way of doing it is to replace the metal pipe that attaches to the water pump with one from an N/A. That pipe doesn't go round the back of the block at all. You can only do that if you disconnect the coolant feeds to the IACV and throttle body though (or don't have any). You can then remove the union that screws into the block and screw in a blanking cap in instead. There's some details of what I did in my engine build thread here.
