Biguns Posted March 9, 2011 Share Posted March 9, 2011 I've just checked that my rear rims are 10J 18" what is the widest tyre size i can get on it? Thx Quote Link to comment Share on other sites More sharing options...
keron Posted March 9, 2011 Share Posted March 9, 2011 I would say safely on a standard arch 275 depends on the offset too...do you know the offset? Quote Link to comment Share on other sites More sharing options...
mr lover Posted March 9, 2011 Share Posted March 9, 2011 check this out big man http://www.carbibles.com/tyre_bible_pg4.html Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 9, 2011 Share Posted March 9, 2011 285/35/18 will be a good fit , do you arched still have the lip Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 9, 2011 Author Share Posted March 9, 2011 No idea what the offset is but i know they are AVS alloys and i need to put spacers on the fronts as there sat in too far on the fronts Quote Link to comment Share on other sites More sharing options...
Nic Posted March 9, 2011 Share Posted March 9, 2011 285/35/18 Quote Link to comment Share on other sites More sharing options...
Biguns Posted March 9, 2011 Author Share Posted March 9, 2011 sweeeeeeeet ^^^^^^^^ Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 10, 2011 Share Posted March 10, 2011 No idea what the offset is but i know they are AVS alloys and i need to put spacers on the fronts as there sat in too far on the fronts If you have to use spacers make sure their hubcentric I posted a tyre fitment chart on here somewhere, if i can find it i'll post it up for you Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 10, 2011 Share Posted March 10, 2011 Here you go Rim width---Min tyre width----Ideal tyre width-------Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted March 10, 2011 Share Posted March 10, 2011 Bear in mind that the thread width can vary a bit from tyre to tyre. I *just* fitted 285/30-18 on my 10J TTE's. And I could definatly go wider (not that I would want to). This is Michelin PS2's. They actually look a bit stretched. If you are looking at the Michelins, let me know and I will take a pic for you. Also, when looking after tyres, it seems to be harder and harder finding these sizes in 18". Most seem to be 19" or even more bling sizes Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 10, 2011 Share Posted March 10, 2011 Thats basically down to differant sidewall profiles and the fitment size should stay the same, even though it looks stretched it actually isnt. Quote Link to comment Share on other sites More sharing options...
