Whats tyre size can i fit
Biguns
No idea what the offset is but i know they are AVS alloys and i need to put spacers on the fronts as there sat in too far on the fronts
If you have to use spacers make sure their hubcentric ;)
I posted a tyre fitment chart on here somewhere, if i can find it i'll post it up for you :)
Here you go
Rim width---Min tyre width----Ideal tyre width-------Max tyre width
7.0 inches-----195 mm--------205 or 215 mm-----------225 mm
7.5 inches-----205 mm--------215 or 225 mm-----------235 mm
8.0 inches-----215 mm--------225 or 235 mm-----------245 mm
8.5 inches-----225 mm--------235 or 245 mm-----------255 mm
9,0 inches-----235 mm--------245 or 255 mm-----------265 mm
9.5 inches-----245 mm--------255 or 265 mm-----------275 mm
10.0 inches----255 mm--------265 or 275 mm-----------285 mm
10.5 inches----265 mm--------275 or 285 mm-----------295 mm
11.0 inches----275 mm--------285 or 295 mm-----------305 mm
11.5 inches----285 mm--------295 or 305 mm-----------315 mm
12.0 inches----295 mm--------305 or 315 mm-----------325 mm
12.5 inches----305 mm--------315 or 325 mm-----------335 mm
Bear in mind that the thread width can vary a bit from tyre to tyre. I *just* fitted 285/30-18 on my 10J TTE's. And I could definatly go wider (not that I would want to). This is Michelin PS2's. They actually look a bit stretched. If you are looking at the Michelins, let me know and I will take a pic for you.
Also, when looking after tyres, it seems to be harder and harder finding these sizes in 18". Most seem to be 19" or even more bling sizes
