Adjustable Car Ramps
JamieP
Yup great way of getting the car off the deck. Think I'll need to be ordering a set of those. I'm with Brendan though, definitely would be going with a set of axle stands at the same time, just to be on the safe side :)
  Wez said:
I saw these on ebay a while back. In some pics they show how using four together gets the whole car up.
Would need to be a fairly high car to manage that one though. 180mm is it at the lowest setting?
  • 9 months later...
  Jurgen-Jm-Imports said:
Mate, is this easy for raising a supra with? thinking about getting one in my garage and sinking it flush in the floor, you had any problems with it?
  merckx said:
A 2 post lift would give you more access to the underside of the car and would be cheaper.
Yep, you can get a decent used 2 post lift for around £500 and either convert to single phase or use a big rotary phase converter. Unless you find a single phase one, or have 3 phase into the house. So long as the ceiling height is adequate to get the posts in you just set the safety stop to come in before the roof of the car hits the ceiling. JamieP is a builder, how about finding one of the old single centre post hydraulic lifts (a bit illegal, but probably OK for private use), dig a big hole in the drive for the centre hydraulics, pave the sunken wheel ramps flush with the path, and no one would know it was even there until you sent the car up :) They'll even rotate to turn the car around to face out of the drive again...
