Tricky-Ricky Posted March 9, 2011 Share Posted March 9, 2011 Need to find out if you can get a cistern/water tank float valve that has a fitting that can take a pipe on the outlet, just like the inlet IE kind of straight through design. Had a look on a few plumbing supply sites but couldn't see anything? Quote Link to comment Share on other sites More sharing options...
Havard Posted March 9, 2011 Share Posted March 9, 2011 I supply tanks but I am confused as to what you are after? H. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 9, 2011 Author Share Posted March 9, 2011 I supply tanks but I am confused as to what you are after? H. I thought i had described what I'm after, but I'll have another go, a ballcock with an outlet the same as the inlet, IE a piece of pipe with a float operated ball valve in the middle? hows that? Quote Link to comment Share on other sites More sharing options...
mark newman Posted March 9, 2011 Share Posted March 9, 2011 Now Iam confused Quote Link to comment Share on other sites More sharing options...
Havard Posted March 9, 2011 Share Posted March 9, 2011 I thought i had described what I'm after, but I'll have another go, a ballcock with an outlet the same as the inlet, IE a piece of pipe with a float operated ball valve in the middle? hows that? I now understand. Why would you want something that operates level control but the inlet water goes down a pipe as opposed to into the tank? H. Quote Link to comment Share on other sites More sharing options...
wallis Posted March 9, 2011 Share Posted March 9, 2011 hey up fella, i understand what u mean no problem there, slightly interested as to why u would want to fit something onto the outlet of a brass or plastic ball valve? I have never seen a ball valve with a half or three quarter inch male iron fitting on it in my life and i do loads of commercial/domestic work. Im not saying they dont exist and im sure one could be made, just not common! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 9, 2011 Author Share Posted March 9, 2011 I now understand. Why would you want something that operates level control but the inlet water goes down a pipe as opposed to into the tank? H. hey up fella, i understand what u mean no problem there, slightly interested as to why u would want to fit something onto the outlet of a brass or plastic ball valve? I have never seen a ball valve with a half or three quarter inch male iron fitting on it in my life and i do loads of commercial/domestic work. Im not saying they dont exist and im sure one could be made, just not common! Its for a level control on a filtration system that needs to have the inlet go through another section first, but with the overall level controlled at another point, hence the through requirement:) Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted March 9, 2011 Share Posted March 9, 2011 Buy the bits and make it, pipe, solder job done. Quote Link to comment Share on other sites More sharing options...
merckx Posted March 10, 2011 Share Posted March 10, 2011 You can buy them in the US on Ebay, they ship worldwide. Looks like £21.57. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350441299948&ssPageName=STRK:MEWAX:IT Or you could get one of these and solder or braze a pipe on. http://www.plumbnation.co.uk/site/brass-ball-float-valve/ball-float-valve.jpg Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 10, 2011 Author Share Posted March 10, 2011 You can buy them in the US on Ebay, they ship worldwide. Looks like £21.57. http://i.ebayimg.com/16/!CCrhOgQEWk~$(KGrHqQOKk!E0dsW3VK4BNL500egUQ~~_35.JPG http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350441299948&ssPageName=STRK:MEWAX:IT Or you could get one of these and solder or braze a pipe on. http://www.plumbnation.co.uk/site/brass-ball-float-valve/ball-float-valve.jpg Thanks for that, i did look on ebay but couldn't find anything like that, number one is the ideal. Quote Link to comment Share on other sites More sharing options...
