my dyno results- big thanks to Ryan and Lee P
Parry_10
Stock J-spec turbos, stock ECU, stock cams, running 1bar and it made 427hp? That figure seems very high for the spec and boost you are running. Are you sure it has stock turbos?
The max I've ever seen stock J-spec turbos produce is around 430hp (flywheel) at 1.2bar, with longer duration cams, ECU, FMIC, etc.
Wondering if the 5spd gearbox has skewed the results, what gear was it dynoed in?
Awww come off it Nic, what's 30hp amongst friends? :D
