brettjones Posted March 8, 2011 Share Posted March 8, 2011 very good numbers well done now enjoy it mate Quote Link to comment Share on other sites More sharing options...
neo2810 Posted March 8, 2011 Share Posted March 8, 2011 Stock J-spec turbos, stock ECU, stock cams, running 1bar and it made 427hp? That figure seems very high for the spec and boost you are running. Are you sure it has stock turbos? The max I've ever seen stock J-spec turbos produce is around 430hp (flywheel) at 1.2bar, with longer duration cams, ECU, FMIC, etc. Wondering if the 5spd gearbox has skewed the results, what gear was it dynoed in? Awww come off it Nic, what's 30hp amongst friends? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 8, 2011 Share Posted March 8, 2011 Nice results, well done, think it was you just leaving as i got there today. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted March 8, 2011 Author Share Posted March 8, 2011 Yeh that would be me mate, cheers guys but i wouldnt have been able to do the conversion on my own if it wasnt for this forum, knowledge from other members and good club spirit so thanks! Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted March 8, 2011 Share Posted March 8, 2011 That is a big BHP figure for 1 bar. I got 422 at 1.25bar with a mines ECU on AFR's rollers. I need to get down to SRR to compare. Either way, that's an excellent result. Quote Link to comment Share on other sites More sharing options...
