Crank pulley alternatives?
The-Plethora
The noise I heard at low speeds that I had down as the power steering pulley seems to actually be the crank, it has got a little worse lately.
Staying away tonight so have to take things a little slow the 40 or so miles home. Are there any alternatives to the stock toyota pulley? I seem to recall this costs aound £260 and then I would need to fit it.
Pic below of the (red) tippex test, it has seperated clearly.
Having a quick browse for e.g...
http://www.toxicspeedshop.com/toyota-supra-mk4-lightweight-crank-pulley-1479-p.asp
Any reason not to look into these? Am I right in thinking the stock one is part metal and part rubber (as it seperates) this replacement is all aluminium, I am guessing there is a good reason Toyota chose that.
Had a look at Whifbitz but seems to only be the idler pulleys.
If anyone close to Bristol can recommend somewhere to swap it out then please let me know, I can even shout "feel the burn" when you are on the breaker bar if you like as I don't have the tools for the job :(.
Edit: is this the same part for the GS300? is there a "supra tax" on them like onb brake discs or can I quote for a GS300 one and get it cheaper?
Edited by The-Plethora (see edit history)
Surprised noone has mentioned the Titan pulley. That is the one that has been recommended to me. Similar price to stock too, although delivery and any taxes will need to go on top.
Titan is a re-badged ATI pulley, have a titan one on mine.
Get an oem one if you don't want to spend too much.
It will probably be an absolute pig to get off aswel. I can recommend a local garage and toyota specialist if you need one.
I used jeff brown ltd on the a38 behind the petrol station (think it's a BP garage) Very good rates and top workmanship. Normally do stuff myself but the other halfs car needed new rear brake lines, real pig of a job.
Jeez! just seen a post from Paul, these are not cheap!
"Crank pulley £265.12 inc VAT, these retail at £331.39!
Fanbelt £31.20 inc VAT
Delivery £10.80 inc VAT"
Is there anything else I need? fanbelt makes sense to change, does the crank pulley come with a bolt or can I get hold of a new one? or are they made of equally expensive Toyota unobtainium? Only just getting over the suspension swapout financially :(
They do seem expensive but just thing how much not replacing it could be if it separates completely I got mine off of Paul Whiffin mate as he was cheapest and the service was top notch too, They're not too difficult to do just need big torque wrench though as they are tight
i wouldn't drive it like that bud, mine went last year and it looked like that. It squeeked when you gave it some pedal and would move everytime you even started the engine. I nursed it to work one day and it popped off when i started it, found it resting on my undertray. Luckily the belt jumped onto the inner ring of the pulley and it carried on running, i can only imagine what damage it would do if it came off at 6k. Whifbitz is the cheapest btw.
Yeah to be fair Paul's prices on the official part are very fair and a decent saving. Managed to get tomorrow off work to get them to look at it, how am I getting it there? Not figured that part out yet.
Is there any mileage in replacing the other pulleys? I can see the logic in getting the propper stock crank pulley as it is weighted properly. The other pulleys seem to just be cast, presumably getting aftermarkets its ok on those?
It is unwise to drive it in that state, should that come off you could be in need of another bonnet.
Another member on here had their crank pulley go and it smashed the bottom of the oil pump, lots of work to put that right.
Pish pash :) made it down ok, went slow and kept constant speed. A bit daft but when you have as much on your credit cards as I do a big bill wont make much difference, wouldnt like to do that again though.
Sat in one of the 23 or so garden centres near pauls having a bun at the moment so can't see how many blokes are hanging from the breaker, fingers crossed.
