Air Con
sideexitsupra
I had the same problem with the flashing light on the AC button when pushed. You could here/see the pump kick in for a few seconds but it would then shut down and the light would start to flash. I ended up replacing the pump with another unit, been fine ever since.
If you search you will see others have had the same problem.
