Josh Posted March 5, 2011 Share Posted March 5, 2011 I really like these. Nice one Quote Link to comment Share on other sites More sharing options...
supraturbochris Posted March 5, 2011 Share Posted March 5, 2011 as josh said +1, quality work matey Quote Link to comment Share on other sites More sharing options...
JakeG Posted March 5, 2011 Share Posted March 5, 2011 They look great, although as pointed out I would be worried about getting it done incase of misting Quote Link to comment Share on other sites More sharing options...
Havard Posted March 5, 2011 Share Posted March 5, 2011 How much would these cost. My lights need a refurb but I was just going to replace them. I can see a trip down to Ric's place..!! H. Quote Link to comment Share on other sites More sharing options...
MattP Posted March 6, 2011 Share Posted March 6, 2011 Rear fog Is a must however front fog lights are not on uk cars however if the car has front fogs fitted they have to work to pass an M.O.T Quote Link to comment Share on other sites More sharing options...
markylee Posted March 6, 2011 Share Posted March 6, 2011 My n/s headlamp has been misting mysteriously for sometime now. I checked everything that could be wrong and everything was fine, it was busting my nads, Last week i took the boot off and haven't had a bit of bother since, in all weathers. I refurbed my lights , and ever since i have had misting up too , can i ask what boot i need to remove, thanks....ps... i have already checked and re sealed them, but i still have the same problem. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted March 6, 2011 Share Posted March 6, 2011 Can someone copy the photo's and attach them instead, i cant view Photobucket links on this rig Quote Link to comment Share on other sites More sharing options...
neo2810 Posted March 6, 2011 Share Posted March 6, 2011 I refurbed my lights , and ever since i have had misting up too , can i ask what boot i need to remove, thanks....ps... i have already checked and re sealed them, but i still have the same problem. I believe they are referring to the little rubber tap type attachment that sticks out the back of the headlight. It's function is to help remove humidity in the light I think, but if it gets clogged up it has the opposite effect. Removing it allows the light to breathe. Of course I could be completely wrong but I have the same issue and will be trying it out today Quote Link to comment Share on other sites More sharing options...
Graham S Posted March 6, 2011 Share Posted March 6, 2011 The front fog light isn't a testable item, so makes no odds if there is a switch for it or not. Quote Link to comment Share on other sites More sharing options...
markylee Posted March 6, 2011 Share Posted March 6, 2011 I believe they are referring to the little rubber tap type attachment that sticks out the back of the headlight. It's function is to help remove humidity in the light I think, but if it gets clogged up it has the opposite effect. Removing it allows the light to breathe. Of course I could be completely wrong but I have the same issue and will be trying it out today ok, thanks for your help Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted March 6, 2011 Share Posted March 6, 2011 Great work, thanks Ric When i fit them back into the car i will post up a before & after pic. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted March 6, 2011 Share Posted March 6, 2011 Just a thought but anyone with preface lift lights like mine could use the old park/side light (bubble thing) for an indicator if you can get an orange cap less bulb? Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted March 6, 2011 Share Posted March 6, 2011 Ive been thinking of trying these too, did you just glue the smd rings onto the plastic insert 'ring' bit? ive always been a bit wary of just gluing it into place....theres quite a neat way of routing the wires through too! ironically using the rubber boot lol. What size rings are you using? (if you dont mind me asking) Good job btw Quote Link to comment Share on other sites More sharing options...
L18msy Posted March 6, 2011 Share Posted March 6, 2011 I refurbed my lights , and ever since i have had misting up too , can i ask what boot i need to remove, thanks....ps... i have already checked and re sealed them, but i still have the same problem. There is a plastic ring around the outside of the dipped beam bulb. It takes a half twist and it is off, haven't had bother since i removed it. Quote Link to comment Share on other sites More sharing options...
neo2810 Posted March 6, 2011 Share Posted March 6, 2011 There is a plastic ring around the outside of the dipped beam bulb. It takes a half twist and it is off, haven't had bother since i removed it. Mate, are you talking about the rubber boot seal which encloses the area around the bulb holder? I've removed it to see what effect it will have but surely youre then exposing the entire inside of the headlight casing to the elements? It leaves a gaping opening right into the headlamp! Quote Link to comment Share on other sites More sharing options...
Tee from China Posted March 7, 2011 Share Posted March 7, 2011 (edited) Very nice Ric, do you think it would be possible to incorporate the facelift sidelight/indicator into that setup such that the first ring acts as a sidelight, and the fog rin flashes amber? Great idea. Is it possible, Ric? Oh how we forget http://www.mkivsupra.net/vbb/showthread.php?85256-front-fog-light-indicator-conversion&highlight=front+fog+indicators plus I thought making your car look like an Audi or Bemmer was naff? or have opinions changed ...yet again Time was when people thought Halo/Angel Eyes or DRL on a Supra where big no nos Edited March 7, 2011 by Tee from China added content (see edit history) Quote Link to comment Share on other sites More sharing options...
marbleapple Posted March 7, 2011 Share Posted March 7, 2011 Oh how we forget http://www.mkivsupra.net/vbb/showthread.php?85256-front-fog-light-indicator-conversion&highlight=front+fog+indicators plus I thought making your car look like an Audi or Bemmer was naff? or have opinions changed ...yet again Time was when people thought Halo/Angel Eyes or DRL on a Supra where big no nos That crossed my mind too. I do love the rear LED lights though. Quote Link to comment Share on other sites More sharing options...
L18msy Posted March 7, 2011 Share Posted March 7, 2011 Mate, are you talking about the rubber boot seal which encloses the area around the bulb holder? I've removed it to see what effect it will have but surely youre then exposing the entire inside of the headlight casing to the elements? It leaves a gaping opening right into the headlamp! Yeah you are right, but trust me i haven't had any bother since i removed it. I have tried everything, i have glass headlamps that have never been split, all the seals are present and correct and even the little rubber drain/breather things are unblocked. Have even tried little bags of silica gel but still no joy, i was ready to stick a hammer through it! Since i removed it the mist/puddle has gone and no rain water has entered the lamp either. Quote Link to comment Share on other sites More sharing options...
mawby Posted March 7, 2011 Share Posted March 7, 2011 Yeah you are right, but trust me i haven't had any bother since i removed it.It seems a bit drastic but if I can't get mine to stop misting up I'll be giving it a go. Quote Link to comment Share on other sites More sharing options...
neo2810 Posted March 7, 2011 Share Posted March 7, 2011 Yeah you are right, but trust me i haven't had any bother since i removed it. I have tried everything, i have glass headlamps that have never been split, all the seals are present and correct and even the little rubber drain/breather things are unblocked. Have even tried little bags of silica gel but still no joy, i was ready to stick a hammer through it! Since i removed it the mist/puddle has gone and no rain water has entered the lamp either. Thx mate, I had stuck mine back in the oven and removed all the vapour, resealed and siliconed them to death, only for the mist to be back worse the next morning. I removed the seal last night and it def looks to be slowly dissipating. Fingers crossed it's gone tomorrow. I'm nearly ready to just buy new facelifts so if this works for a while and then the hole slowly destroys them, I've lost nothing Quote Link to comment Share on other sites More sharing options...
L18msy Posted March 7, 2011 Share Posted March 7, 2011 If the sun makes an appearance park it with the sun shining on the lights it will go quicker with the heat on them or pop them in the oven again and refit them without the ring on. Quote Link to comment Share on other sites More sharing options...
KrisM Posted March 7, 2011 Share Posted March 7, 2011 If youve got the button, the light needs to be there and work correctly... not having the button and you should be fine Black nail varnish over the symbol indicating it operates front fogs. They can't say/do anything with that. Quote Link to comment Share on other sites More sharing options...
L18msy Posted March 7, 2011 Share Posted March 7, 2011 Black nail varnish over the symbol indicating it operates front fogs. They can't say/do anything with that. Use black nail varnish often Kris?? Quote Link to comment Share on other sites More sharing options...
marbleapple Posted March 7, 2011 Share Posted March 7, 2011 Might sound dumb but do you have the correct bulbs in and fitted correctly? I am led to believe that some are smaller than others surround wise and this the fit let's moisture in. Im Sure I read some where that jap and uk headlight bulbs are different sizes and it's easy to mix them up (I.e uk lights but jap size bulbs etc) Quote Link to comment Share on other sites More sharing options...
L18msy Posted March 9, 2011 Share Posted March 9, 2011 Any joy with this lads? Quote Link to comment Share on other sites More sharing options...
