Enging warning light / Oil light / ABS light
JS2004
Ive had the dash out today and put it back in, noticed the normal ABS light and other lights did not show up when I put the key in the ignition.
Took the dash apart again and fiddled with the connector. It is behaving as if the wires are crimped or just a bad connection..
Its currently working now after tapping the screen, but the roads round here are less than pothole free (some areas look like the moons surface) so it wont be long until its shaken back to the point of no lighty.. which I no likey.
So I am reckoning its a bad connection (although the plugs in as far as it will go) or the wires themselves are damaged.. Are these easy to replace?
I don't think its the dash part itself as I can squeeze the plastic covering around the bunch of smaller wires and this makes the lights show up again.
Anyone had similar problems and got a way to fix it? I imagine its not too rare of an issue but all the searches I have done come up with results caused by not plugging stuff in, or fuses blowing.. neither of which is the case as it works, then doesn't, then does, then doesn't etc..
Cheers guys, I have had the plug in and out a few times. I pushed it in as far as it could go whilst the dash panel was out, and its still the same result, so thinking its more likely the joints as pointed out by Kyle.
Ill have a go at sorting that out.
Thanks =)
