brakes help
Guest jon348
Guest jon348
does anyone know if there is an online guide to replacing brakes, I am having so much trouble getting the discs off!!
please help, cheers jon
Quite, I hope you haven't undone the rear hub nut thinking it has to come off to remove the rear discs? You may need to adjust the handbrake shoe star wheel adjuster for the handbrake drum shoes, for the rear disc to come off. It's accessed through a hole in the wheel face of the disc, and the hole should be blanked with a rubber grommet. The adjuster is at 6.00 o'clock, at the bottom, you may need to shine a pencil torch through the hole to line the star wheel up with the access hole. Turn it with a flat baladed screwdriver through the hole to bak off the shoes away from any wear lip. If in doubt get a pro to help.
(She'll take your mind off the unpleasantness of the job :))
