The bog won't flush.
tbourner
Thanks!
It does have 'Metro' on it as well, just needed a wipe to see it. Looks to be about 220mm, but I'm having trouble unscrewing the blue nut, might have to take the ball out to make room.
The measurement is in imperial, to the nearest 1/2" IIRC. Just stop the water supply to the cistern, empty it then spray around the nut with WD40. Leave it for a while, then try it (try using the syphon chamber as leverage, as you'll get more 'purchase')
This wasn't a good time to walk in mid thread..... :shock:
It's like something from 'Carry On at Your Convenience' - I'm just waiting for Kenneth Williams to pop up and say 'OOOOOOH'
Got a new valve flap instead of the whole unit as PlumbCentre didn't have the same type. It now flushes but I had to take the ballcock assembly out to get the syphon unit in and out. Now I've got a leak on the inlet to the cistern. D'OH. Hopefully if I get a rubber washer it'll stop it? Or do I need sealing compound and stuff as well? It's a plastic hexagon nut that you hand tighten and I've got it as tight as I can.
