Bloody Computer!
Dragonball
My desktop was frozen when trying to shut off - so I hit and pressed the button and it duly closed down... standard numpty response
Now when it boots up it only shows the 'documents' screen oh and the screen saver photo- no start and icon tray -
Switched on/off etc
Have tried to open in safety mode - still the same
Tried reopening to prior config - still same
Tried safety with command prompt and only shows run documents
Could anyone please advise me what I should do when I get home tonight?
Many thanks
What OS are you using? XP? 7? I would be tempted to repair the installation. If you don't have an installation CD for it, I think Windows lets you make a recovery disk using a different computer (not sure where, it's ages since I've had to do it).
Before you try anything, try to back up any important docs/photos/emails/etc you have: you can probably bring your PC back without too much drama but it's still a good idea.
Sorry if that's a bit vague: all from fairly distant memory.
EDIT: by "recovery disk", I actually meant "system restore". Don't use the System Recovery option from a hard drive image unless as a last resort: you'll roll your PC back to the day it left the factory. :(
Try CTRL-ESC
If that doesn't work hit CTRL-ALT-DEL, click the "File" menu then click "Run", type in "Explorer.exe" and hit enter.
If that doesn't work I would try a system repair (complex depending on the OS)
If that doesn't work it's re-install time.
Didnt think file was an option Scott??
Ctrl+Alt+Delete
Start task manager
Run Explorer
have a snoop around, try to fix else fire a system restore.
Good luck
Not really sure what you mean? How do you "run explorer" without first clicking the "File" menu and clicking "New Task(run...)"?
  • 2 weeks later...
Thanks for suggestions guys - sorry for not posting before.
I had to do a re install of XP and repair...all works OK - apart from the 9000 windows updates :-(
Cheers for help
in situations such as these - one person comes to mind again ;)
