car not firing
Guest blueangel
Guest blueangel
done it twice now atleast fella even put the old loom back in to see if its the new loom at fault this has me completely baffled
If you have fuel and spark then you shouldn't be having any issues (other than timing but you would get a splutter)
Sounds like it is either the coil pack clips, the coil packs or the spark plugs. Give all the plugs a clean and try again. If that doesn't work you will need to do the same test on each of the coil packs/clips/plugs.
Guest blueangel
im gonna try new plugs in the morning i have some keron gave me been meaning to do it anyway lol thanks for the help guys ill keep you updated
