japke_mk4 Posted March 1, 2011 Share Posted March 1, 2011 (edited) hello i got a qeustion for my turbo bild i dont know how mutch i need for the headet gasket (metal ) like 1.6mm cometic gasket or more or ... can sombody help me whit it ? my spec's are in my profiel frome showroom ore here spec list : its a NA block but i wanne bild a singel turbo conversion i got almost evrything exapt - 3.0 2jzge clutch: spech stage 5 flywheel : alu fixdanza gearbox : 5 bak sperdifrentiele : 95 procent airintake : apexi turbo : Precision Turbo T71 Turbocharger Capable of 925HP featuring a Billet Compressor Wheel spruitstuk : boostlogic T4 downpipe : boostlogic 3" BOV : HKS ssqv3 wasgate : extern HKS intercooler: xsp 3" piping : boostlogic 2.5" ecu : greddy emange ultimate + harnas cams : aem ejustibel uitlaat: motoria decat : japspeed turbo timer : apexi limetetd edion blauw olie catch can : NRG polich strutbar : alutech midpipe : 3" japspeed feulpomp : 2x walbro 255 injecetors : 1000cc HKS - feul rail : HKS - belt : greddy boostcontroler : aem tru boost black olie druk meterke : aem black - olie meterke : aem black - AF meterke : aem black - wide band : aem black - gauges pod : hoop op new abflug style metal gasket : cometic - heedbolts : ARP - spark plugs: ngk-r intake : 4" k&n oliecooler :mocal cora 16 row+ thermostaat radiator - reagerds kevin and sorry about the bad english :$ Edited March 1, 2011 by japke_mk4 (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 1, 2011 Share Posted March 1, 2011 I can't find the spec, have you got a direct link? Need to know what cams, if none stock pistons and what are the CR specs on the sheet with them, and if any block or head machining has been done. Boost you want to run? Fuel you want to run? Quote Link to comment Share on other sites More sharing options...
japke_mk4 Posted March 1, 2011 Author Share Posted March 1, 2011 http://www.mkivsupra.net/vbb/showthread.php?240524-hellow link too me Quote Link to comment Share on other sites More sharing options...
