dude Posted February 27, 2011 Share Posted February 27, 2011 Joined a Tri chevy forum and found this, don't know if the link will work. http://www.trifive.com/horsepower/horsepower.htm Its american so your weight needs to be in lbs. Quote Link to comment Share on other sites More sharing options...
Westy Posted February 27, 2011 Share Posted February 27, 2011 Link works fine. Not sure on the inputs to categorically state it works though! Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 27, 2011 Share Posted February 27, 2011 Tt with almost 16 stone chap in it is 3440 lbs. With my et and 1/4 time it says my car is about 50bhp short of were it actualy is. Quote Link to comment Share on other sites More sharing options...
dude Posted February 27, 2011 Author Share Posted February 27, 2011 JP's comes to 706 hp not a million miles out I would say. Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted February 27, 2011 Share Posted February 27, 2011 While were on the subject, how accurate is this one? http://letstorquebhp.com/calculator.asp Reason i ask is because i've never run mine down a strip, so dont know what time's it would make. Just wondered if any of you guys with quater mile times could check. According to the list of rear whell drive cars on the left the supra weighs 1549 KG, but obviously some of you have stripped weight out. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 27, 2011 Share Posted February 27, 2011 While were on the subject, how accurate is this one? http://letstorquebhp.com/calculator.asp Reason i ask is because i've never run mine down a strip, so dont know what time's it would make. Just wondered if any of you guys with quater mile times could check. According to the list of rear whell drive cars on the left the supra weighs 1549 KG, but obviously some of you have stripped weight out. Seems reasonable. I typed in approx BPU figures and got 12.6 seconds. Should be about right for a good driver in street trim with decent rubber. Coupling in a drag setup with high stall or fast gear changes (in a manual) you can hit 11.5 Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 28, 2011 Share Posted February 28, 2011 Seems reasonable. I typed in approx BPU figures and got 12.6 seconds. Should be about right for a good driver in street trim with decent rubber. Coupling in a drag setup with high stall or fast gear changes (in a manual) you can hit 11.5 My best ever was 12.7 so sound about right Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 28, 2011 Share Posted February 28, 2011 While were on the subject, how accurate is this one? http://letstorquebhp.com/calculator.asp Reason i ask is because i've never run mine down a strip, so dont know what time's it would make. Just wondered if any of you guys with quater mile times could check. According to the list of rear whell drive cars on the left the supra weighs 1549 KG, but obviously some of you have stripped weight out. I always use that as so far its been the most realistic, it said my pulsar should hit 60 in 3.8, I did it in 3.9, my 1.8 NA mx5 would do the 1/4 in 15.8, I did 15.7 but could easily do a mid to low 15. Quote Link to comment Share on other sites More sharing options...
