Guest anesn Posted February 27, 2011 Share Posted February 27, 2011 Hey, the car has been standing for about 5-6 months now, And i started the car for about 3 days ago gassed a bit in neutral was how nicely and evenly, as usual, switched it off. i didnt drive it but i rev it and it sounded just fine.. And yesterday when i wanted to fix the exhaust catalysators and the new air filter it started to act realy strange it didn't want to rev here is a movie of it ... I don't realy know what the problem is , but some tips would help what can make a car behaving like this ps im from sweden ty! Updated: http://www.youtube.com/watch?v=hsHosYelMJw http://www.youtube.com/watch?v=c04buj_t-r4 NOTE THE HOWLING SOUND IS MADE WORSE BY THE CAMERA... Quote Link to comment Share on other sites More sharing options...
Guest anesn Posted February 27, 2011 Share Posted February 27, 2011 anyone?? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 27, 2011 Share Posted February 27, 2011 The first thing i'd do is check/test the spark plugs, then the coilpacks. Quote Link to comment Share on other sites More sharing options...
Bailey. Posted February 27, 2011 Share Posted February 27, 2011 My rx7 was a bastard for fowling plugs, I had this with that, crazy antilag sound even on light throttle, removed plugs and replaced and it was sweet, give it a go. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted February 28, 2011 Share Posted February 28, 2011 The first thing i'd do is check/test the spark plugs, then the coilpacks. Same here. That would by my first port of call. Quote Link to comment Share on other sites More sharing options...
Guest anesn Posted March 12, 2011 Share Posted March 12, 2011 Hey i called a supra friend and i took parts from her car it didn't help realy Tried coilpacks, ECU, Sparkplugs map sensor, checked with a camera down into the cylinders looked good. Any more tips? what could it be Quote Link to comment Share on other sites More sharing options...
Guest anesn Posted March 13, 2011 Share Posted March 13, 2011 any more tips anyone? Quote Link to comment Share on other sites More sharing options...
dude Posted March 13, 2011 Share Posted March 13, 2011 Have you reset the ecu Quote Link to comment Share on other sites More sharing options...
dude Posted March 13, 2011 Share Posted March 13, 2011 Unplug the ignitor pack and spray some water dispersant in the plug, also check the coil pack plugs very closely to make sure the wires arent bared and touching close to the actual plugs. Quote Link to comment Share on other sites More sharing options...
Guest anesn Posted March 13, 2011 Share Posted March 13, 2011 i tried with a other ECU as you can se in a post above Quote Link to comment Share on other sites More sharing options...
dude Posted March 13, 2011 Share Posted March 13, 2011 Thats not the ignitor pack or wires to the coil packs though is it, also test the map sensor and there is a little black canister screwed into the plenum just infront of the IAC valve, remove that and make sure it is clear, it will have a small vac pipe on it. Quote Link to comment Share on other sites More sharing options...
Guest anesn Posted March 13, 2011 Share Posted March 13, 2011 i wrote a post earlier that says what i have dested, i've tested everything you wrote:P gonna check camshaft and crank shaft what OHM They have Quote Link to comment Share on other sites More sharing options...
dude Posted March 14, 2011 Share Posted March 14, 2011 OK but you have not checked what I told you too, we have had a few do this and itrs been the wires to the coil packs shorting together in the loom, these looms are now old and the integrity of the wires is in doubt. As you seem sure you know best I will wish you luck and not post again. Quote Link to comment Share on other sites More sharing options...
