Samurai 20V Posted February 26, 2011 Share Posted February 26, 2011 Hi..Need some help with brakes discs and pads choices...I have UK spec brakes.. Here are the options. 1. TRD Front Pads (Red spec or black spec) and Discs with Dixcel Rear discs and pads. 2. Same as above except TRD Black RRs. 3. Dixcel Discs and Pads. The dixcels can be bought slotted with heat treatment or w/o.. What to do? Help please! Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted February 26, 2011 Share Posted February 26, 2011 Is your car only ever run on the road or do you track it too? Lots of fancy stuff out there but check with Paul at Whifbitz about Porterfield pads. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 26, 2011 Share Posted February 26, 2011 What are you using it for? If its just road then OE Toyota discs and pads will be fine and save you some money Ill bet. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 26, 2011 Share Posted February 26, 2011 Hi..Need some help with brakes discs and pads choices...I have UK spec brakes.. Here are the options. 1. TRD Front Pads (Red spec or black spec) and Discs with Dixcel Rear discs and pads. 2. Same as above except TRD Black RRs. 3. Dixcel Discs and Pads. The dixcels can be bought slotted with heat treatment or w/o.. What to do? Help please! Dixcel products are good quality as are the TRD. With the discs I'd go for the cheapest option or just fit a set of stock discs which will be just as good. If you fancy spending big money, a set of Project Mu SCR Pro would be my ultimate choice. Given the choice I'd go for a set of Endless MX72 Pads they're probably similar price to the TRD red pads. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted February 27, 2011 Author Share Posted February 27, 2011 Dixcel products are good quality as are the TRD. With the discs I'd go for the cheapest option or just fit a set of stock discs which will be just as good. If you fancy spending big money, a set of Project Mu SCR Pro would be my ultimate choice. Given the choice I'd go for a set of Endless MX72 Pads they're probably similar price to the TRD red pads. Thanks Nic. Getting the Dixcel discs, normal slotted. Pads, the Endless MX72 is 30000yen, TRD black is 19600yen. Which would you recommend based on cost and performance? Quote Link to comment Share on other sites More sharing options...
Nic Posted February 27, 2011 Share Posted February 27, 2011 (edited) Thanks Nic. Getting the Dixcel discs, normal slotted. Pads, the Endless MX72 is 30000yen, TRD black is 19600yen. Which would you recommend based on cost and performance? The TRD black pads are good, the Endless MX72 are VERY good, they are worth the extra but depends how much you want to spend. http://www.endlessusa.com/brakepad/mx-72/ Edited February 27, 2011 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted February 27, 2011 Author Share Posted February 27, 2011 The TRD black pads are good, the Endless MX72 are VERY good, they are worth the extra but depends how much you want to spend. http://www.endlessusa.com/brakepad/mx-72/ Thanks Nic.. Ordering the Endless... Quote Link to comment Share on other sites More sharing options...
Nic Posted February 27, 2011 Share Posted February 27, 2011 Thanks Nic.. Ordering the Endless... Good choice you won't be disappointed What front tower bar did you decide on? The Carbing one includes a brace for the brake master cylinder which really helps firm up the pedal feel. If you're fitting a TRD Tower Bar you may want to consider a Cusco Brake Master Cylinder Stopper which does the same thing. Carbing Tower Bar http://img46.imageshack.us/img46/2775/attachment1phpdh1.jpg Cusco Brake Cylinder Stopper http://img210.imageshack.us/img210/7042/attachmentphpib1.jpg Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted February 28, 2011 Author Share Posted February 28, 2011 Thanks Nic. I couldnt find the Carbing Front tower bar, only the rear. I will keep checking, if I cant find it then I will get the TRD. Will check for the Cusco Brake cylinder stopper, and if fitting the TRD bar will fit that as well. Will keep you posted! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 28, 2011 Share Posted February 28, 2011 I've put together some brake packages here http://www.mkivsupra.net/vbb/showthread.php?239253-Brake-Upgrade-Packages if that helps you at all? Also sell the Cusco MC stopper which you can see here http://whifbitzperformancetuning.co.uk/toyota-supra-brake-parts-hosesfluid-accessories-cusco-p-5429.html Thanks Paul Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted February 28, 2011 Author Share Posted February 28, 2011 I've put together some brake packages here http://www.mkivsupra.net/vbb/showthread.php?239253-Brake-Upgrade-Packages if that helps you at all? Also sell the Cusco MC stopper which you can see here http://whifbitzperformancetuning.co.uk/toyota-supra-brake-parts-hosesfluid-accessories-cusco-p-5429.html Thanks Paul Thanks Paul, I have already ordered the Dixcel SD and Endless MX72.. I am most likely gonna order the 2.5inch decat from you, if I cant get the Cusco stopper in Japan, will get it from you then. Quote Link to comment Share on other sites More sharing options...
Guest kanekane Posted February 28, 2011 Share Posted February 28, 2011 Check on ebay, I paid mine 68$us shipped (USA - Canada) http://cgi.ebay.com/ebaymotors/Toyota-Supra-93-98-JDM-Master-Brake-Cylinder-Stopper-_W0QQcmdZViewItemQQhashZitem3eefe68373QQitemZ270312833907QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment Share on other sites More sharing options...
