Brakes - Discs and Pads
Samurai 20V
Hi..Need some help with brakes discs and pads choices...I have UK spec brakes..
Here are the options.
1. TRD Front Pads (Red spec or black spec) and Discs with Dixcel Rear discs and pads.
2. Same as above except TRD Black RRs.
3. Dixcel Discs and Pads.
The dixcels can be bought slotted with heat treatment or w/o..
What to do? Help please!
Dixcel products are good quality as are the TRD. With the discs I'd go for the cheapest option or just fit a set of stock discs which will be just as good. If you fancy spending big money, a set of Project Mu SCR Pro would be my ultimate choice.
Given the choice I'd go for a set of Endless MX72 Pads they're probably similar price to the TRD red pads.
Thanks Nic.
Getting the Dixcel discs, normal slotted.
Pads, the Endless MX72 is 30000yen, TRD black is 19600yen. Which would you recommend based on cost and performance?
Thanks Nic.
The TRD black pads are good, the Endless MX72 are VERY good, they are worth the extra but depends how much you want to spend.
http://www.endlessusa.com/brakepad/mx-72/
Thanks Nic..
Ordering the Endless...
Good choice you won't be disappointed :thumbs:
What front tower bar did you decide on? The Carbing one includes a brace for the brake master cylinder which really helps firm up the pedal feel. If you're fitting a TRD Tower Bar you may want to consider a Cusco Brake Master Cylinder Stopper which does the same thing.
Carbing Tower Bar
http://img46.imageshack.us/img46/2775/attachment1phpdh1.jpg
Cusco Brake Cylinder Stopper
http://img210.imageshack.us/img210/7042/attachmentphpib1.jpg
I've put together some brake packages here http://www.mkivsupra.net/vbb/showthread.php?239253-Brake-Upgrade-Packages if that helps you at all?
Also sell the Cusco MC stopper which you can see here http://whifbitzperformancetuning.co.uk/toyota-supra-brake-parts-hosesfluid-accessories-cusco-p-5429.html
Thanks
Paul
Thanks Paul, I have already ordered the Dixcel SD and Endless MX72..
I am most likely gonna order the 2.5inch decat from you, if I cant get the Cusco stopper in Japan, will get it from you then.
