Steve Posted June 25, 2005 Share Posted June 25, 2005 Where do people mount the emanage control unit? Just wanted to start running some wires before Vortex finish the rest Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 I put mine just below the radio in that double din slot... The other choice is to modify the centre console bit by your arm and put it in there.. Gav Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Do you mean the control bit (E01)? I meant the big blue main unit that all the wires plug in to. Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Yeah, I meant the actual emange, not the profec unit.. Gav Quote Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 I put it under the passenger seat...others mount it to the passenger side of the gearbox tunnel...both are under the carpet and hidden from view. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Cheers guys Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 25, 2005 Share Posted June 25, 2005 I've started to put them by the gearbox tunnel, as Alex said. We used to put them under the centre console armrest, but Ian moaned at me, so they all go by the tunnel now Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Cheers Matt Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Sorry guys How do you mount it to the tunnel? Quote Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 Big velcro strips is easiest as it's not a flat surface. Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 6 inch nails and a big hammer *grin* Double sided velcro and trim the carpet so you can tuck the wires behind the carpet to look sweet... Gav Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Cheers again. Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Us emanage boys have to stick together against the Motec and AEM boys *grin* Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Sorry again guys. Can the emanage be used as a FCD aswell or do i need a seperate FCD.? Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Nope, it doesn't work as an FCD.... as it doesn't link into the MAP sensor... Gav Quote Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 Sorry again guys. Can the emanage be used as a FCD aswell or do i need a seperate FCD.? On an Jspec before 1997.7 yes. On a UK or post 1997.7 spec Supra No. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Will get a FCD sorted then. Cheers Gav Quote Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 What year is yours Smarty?? See my post above. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 On an Jspec before 1997.7 yes. On a UK or post 1997.7 spec Supra No. Ok, mines a 1996 j spec. So i can use the emanage then. I presume you set the cut level through the software then? Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Sorry, yes alex is correct.... I was talking from my experience on my car (99)... Gav Quote Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 Yes you do cause you WILL use the MAP sensor for your fuel map. Your setup will be the same as Ian's FC occurs about 4.40v but you'll never hit that with bigger injectors, as you'll be backing the fueling off so much. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2005 Author Share Posted June 25, 2005 Ok, i'll cross the FCD off the list. Once again cheers guys. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 25, 2005 Share Posted June 25, 2005 Mine is to the right of the ECU in passenger footwell, behind the cover Quote Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Nic, What are the chances you get the emanage ultimate over there.... As a I reckon a few people will want them... Gav Quote Link to comment Share on other sites More sharing options...
