needy Posted February 25, 2011 Share Posted February 25, 2011 fuel pump 12v mod 2jzgte jdm hello friends Anybody know how to make the correct 12v to fuel pump on a 2jzgte jap spec. would like to use a relay, but the wires going to huh? relay have 4 outputs 30 voltage + 87 85 86 what wire must go to what leg in the relay wish if you can make a guide with pictures&/ill Quote Link to comment Share on other sites More sharing options...
Wez Posted February 25, 2011 Share Posted February 25, 2011 Why are you doing it, its an old mod that is no longer used and has safety issues Quote Link to comment Share on other sites More sharing options...
needy Posted February 25, 2011 Author Share Posted February 25, 2011 because, i have a fcd and what to raise to 1.2 bar on my turboes.. Quote Link to comment Share on other sites More sharing options...
Thorin Posted February 25, 2011 Share Posted February 25, 2011 I wouldn't bother. Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted February 25, 2011 Share Posted February 25, 2011 i havnt bothered and mines fine Quote Link to comment Share on other sites More sharing options...
needy Posted February 25, 2011 Author Share Posted February 25, 2011 can you trye to explain why, since there are so many different opinions about it? Quote Link to comment Share on other sites More sharing options...
Thorin Posted February 25, 2011 Share Posted February 25, 2011 can you trye to explain why, since there are so many different opinions about it? My opinion is the only one you should be worrying about Quote Link to comment Share on other sites More sharing options...
needy Posted February 25, 2011 Author Share Posted February 25, 2011 My opinion is the only one you should be worrying about what? Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted February 25, 2011 Share Posted February 25, 2011 basicly you dont need to do it, if your worried about fueling either get an afr gauge or get the car on a dyno to make sure its running ok on 1.2bar! Quote Link to comment Share on other sites More sharing options...
needy Posted February 25, 2011 Author Share Posted February 25, 2011 basicly you dont need to do it, if your worried about fueling either get an afr gauge or get the car on a dyno to make sure its running ok on 1.2bar! i have a afr gauge on the car.. But as we now talk about it, what do the AFR shows usually at idle speed? Quote Link to comment Share on other sites More sharing options...
Wez Posted February 25, 2011 Share Posted February 25, 2011 i have a afr gauge on the car.. But as we now talk about it, what do the AFR shows usually at idle speed? It will bounce around a bit while it tries to correct the fueling but it should be aiming for around 14.7afr at idle. Quote Link to comment Share on other sites More sharing options...
needy Posted February 25, 2011 Author Share Posted February 25, 2011 It will bounce around a bit while it tries to correct the fueling but it should be aiming for around 14.7afr at idle. ok. mine shows about 14.8 til 15.2 at idle speed. somthing to worry about? Quote Link to comment Share on other sites More sharing options...
Wez Posted February 25, 2011 Share Posted February 25, 2011 ok. mine shows about 14.8 til 15.2 at idle speed. somthing to worry about? Doesnt sound too bad, what make gauge do you have? Quote Link to comment Share on other sites More sharing options...
needy Posted February 25, 2011 Author Share Posted February 25, 2011 i have a aem wideband air/fuel ratio gauge Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 25, 2011 Share Posted February 25, 2011 i have a aem wideband air/fuel ratio gauge Its sounds like it's completely knackered. You might as well send it to me. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 25, 2011 Share Posted February 25, 2011 Fit a new Walbro Fuel Pump (Part no. GSS342) and it'll be fine at 1.2bar, don't mess with the wiring, tried and tested 100's of times. Have a read of this -> BPU if you haven't already. Quote Link to comment Share on other sites More sharing options...
