Rear disc changing
Dim Sum
Guest George89
you don't need to screw it evenly. Its the easiest way too get the rear discs off without breaking anything. Put a screw on the top hole which would push the disc at the top out. Then unscrew it and put it in the bottom hole and the disc should pop out. its the easiest way.
I give it ago today looking out what i've being told and still i don't have a clue, it looks like the disc is stuck for good. I know the brakes are on it, i forgot to take a picture when its off. On the third picture if you look at the middle round circle it looks to me that it can't be taken off.:(
The cogs at the bottom. Release the handbrake, remove the rubber grommet from the disk, rotate the disc so the hole is at the 6 o'clock position and with the aid of a torch you will see the cog inside which can be turned using a flat screwdriver which will release the shoes.
Edit as monsween said :)
Thanks for everyones input. In the end, i just got a hammer and bashed it out........ nothing broke, i think the handbrake shoe, springs fell out other then that its okay. Put everything back together and so far its seems fine.......
This is the right hand side disc.
Edited by Dim Sum (see edit history)
