RobD Posted February 23, 2011 Share Posted February 23, 2011 Once the single has been put in I want to add a ridox kit to my car! I'm not going wide arch all round but just at the rear! Thing is the arches are 50mm wider either side and I need to get a set of alloys that'll fit nicely with uk spec Or bigger brakes and preferably without the need of spacers! I've found a few sets of alloys that can be made to any size I want but I'm just not sure what offsets I'll need to fit the rear! Can anyone tell me a way of finding out? Any advice/help gratefully recieved Quote Link to comment Share on other sites More sharing options...
Nic Posted February 24, 2011 Share Posted February 24, 2011 On a stock bodied Supra 18x10 +35 wheels fill the arches. If the arches are 50mm wider on the rear to get the same look with the same width wheels you would need 18x10 -15. Alternatively you could go for wider wheels on the rear eg. 18x12 +10 The 2pot rear calipers are not too wide so clearance isn't usually a problem, it is the larger 4 pot front calipers that need more clearance. Any decent wheel supplier should be able to advise on the offset/disc of the wheels you need. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 24, 2011 Share Posted February 24, 2011 This OFFSET CALCULATOR is useful for comparing wheel widths/offset. If you assume 18x10 +35 will fill the arches of a stock bodied Supra you can put these sizes in the calculator and then compare different widths and offsets. Quote Link to comment Share on other sites More sharing options...
RobD Posted February 24, 2011 Author Share Posted February 24, 2011 Thanks Nic that's a great help Quote Link to comment Share on other sites More sharing options...
