pistol pete Posted February 23, 2011 Share Posted February 23, 2011 (edited) hi all just got me supra home.. but please help as this might become a big issue and i want to sort it asap.. basically the car drives perfectly not clutch slip or anything like that.. but if you hold the clutch pedal down for more than about 2 seconds on the floor it comes up enough for the clutch to bite but the stops coming back up and sticks.. it doesnot make a difference if you try and put the clutch back down and the gear stays selected and unable to take out.. you have to pysically get you foot under the pedal and flick it up.. its only when the engine is running. and it changes gear drives fine.. just when foot is down at the floor for a couple of secomds.. please help me sort this.. its a 5 speed L reg NA te car has sat for around 6 months.. Edited February 23, 2011 by pistol pete (see edit history) Quote Link to comment Share on other sites More sharing options...
pistol pete Posted February 23, 2011 Author Share Posted February 23, 2011 also noticed the engine managment light does not work.. is it easy to get the dash off to check them.. the car drives well and seems to have no problems.. Quote Link to comment Share on other sites More sharing options...
pistol pete Posted February 23, 2011 Author Share Posted February 23, 2011 just been looking at it does do it when engine is not running.. i am thinking clutch master cylinder is jamming if its worn and twisting slghtly in the cylinder... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 23, 2011 Share Posted February 23, 2011 I would remove strip and clean both master and slave cylinders and fit repair kits available from Toyota. Fill with frsh fluid and bleed, and it will probably be fine. The master cylinder vent hole is probably blocked with *rap from worn seals and aging fluid. If you are not 100% confident stripping hydraulics get a decent garage to do it. Quote Link to comment Share on other sites More sharing options...
jonc Posted February 23, 2011 Share Posted February 23, 2011 Pete, Sounds like the master or slave are slipping back. If the car has been stood for so long it may be worth getting the seal kits for both and refurbishing them. I've not done it on the Sup but you should be able to undo the slave from the clutch, get some one to press the clutch pedal and you can watch the movement of the cylinder. The hydraulic system for a clutch is fairly basic to be honest as long as you keep everything clean when your working on it. The part of the dash where the warning bulbs are is 5 screws passing through the upper panel into the main dash. Read this and it will give you an indication on the panel removal which will give you access to the warning light panelshttp://www.mkiv.com/techarticles/boostguage/bg.htm Hope this helps Quote Link to comment Share on other sites More sharing options...
pistol pete Posted February 24, 2011 Author Share Posted February 24, 2011 thanks guys i have been told by SWMBO that i am out this afternoon so friday i will have a look.. thanks Quote Link to comment Share on other sites More sharing options...
pistol pete Posted February 24, 2011 Author Share Posted February 24, 2011 anyone got any pics of where the slave cylinder is.. thanks Quote Link to comment Share on other sites More sharing options...
pistol pete Posted February 24, 2011 Author Share Posted February 24, 2011 how easy is it to rebuild the master cylinder.. pick up the bits 2morrow.. cheers Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 24, 2011 Share Posted February 24, 2011 If you have internal circlip pliers, brake seal assembly grease (which may be in the kit) or second best clean fresh brake fluid (DOT 3, DOT 4, or DOT 5.1 **NOT DOT 5**), pretty straightforward. It's all in the Toyota manual which you can probably download. Quote Link to comment Share on other sites More sharing options...
pistol pete Posted February 24, 2011 Author Share Posted February 24, 2011 cool thanks., i am and engineer so hopefuly can work it out.. also is there any adjust ment on the pedal.. if it did not go all the way to the ground.. maybee 4mm up the it might be okay.. Quote Link to comment Share on other sites More sharing options...
fastcar Posted February 24, 2011 Share Posted February 24, 2011 The slave cylinder is on the pasanger side of the gearbox towards the front. It has a small diameter pipe coming out of the back of it connecting to a 10 or 12mm rubber pipe. There is two bolts either 12 or 14mm remove them and will just pull out. Quote Link to comment Share on other sites More sharing options...
