hp006 Posted February 22, 2011 Share Posted February 22, 2011 I have changed the front hubs over. I am now trying to swap the rears over to add the abs sensor. I have undone all bolts and am down to the last ball joint. I can not remove this for love nor money. I have tried forked ball joint remover, scissor type ball joint remover hitting the ball joint on the side. Non of these techniques have realesed it. The drive shaft is loose as well so it is only the last ball joint holding the hub on. http://s3.postimage.org/1k9hm451g/IMAG0017.jpg Am i missing something? Is there a different technique to remove the bottom side?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 22, 2011 Share Posted February 22, 2011 Big block of steel one side of the female part of the coupling, and the ball of a ball pein on the opposite side, or as opposite as access allows. Ideally you need an assistant. The shock slightly deforms the taper and the joint separates. a fork tool just destroys the rubber dirt boot. Quote Link to comment Share on other sites More sharing options...
hp006 Posted February 22, 2011 Author Share Posted February 22, 2011 Whats the difference of hitting it with a ball pein hammer and just a hammer? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 22, 2011 Share Posted February 22, 2011 The ball concentrates the force. Quote Link to comment Share on other sites More sharing options...
EdMorris Posted February 22, 2011 Share Posted February 22, 2011 I did this and had the exact the same problem. Using Chris's technique helped but I still fooked the ball joint and had to get new suspension arms as a new ball joint only comes with a new arm. Still, it will transform the rear handling so thats a plus. Silver lining and all that. Good luck and be patient, unlike me. Try some heat too if you have something strong enough. Quote Link to comment Share on other sites More sharing options...
bignum Posted February 22, 2011 Share Posted February 22, 2011 A long extension bar on the nut with the nut on 4/5 turns, hit extension bar with lump hammer, access can be tight, try not to bash the wheel arch in! Quote Link to comment Share on other sites More sharing options...
hp006 Posted February 22, 2011 Author Share Posted February 22, 2011 ok i will try the above as well. Is there a particular place to hit the ball joint. From watching a clip on u tube they say there sud be a line which i can see on all the other joints but not the one thats left? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 22, 2011 Share Posted February 22, 2011 i used a hgv ball joint splitter , 32mm socket and an impct wrench and off she flew... literally so be carefull Quote Link to comment Share on other sites More sharing options...
