adi2009 Posted June 24, 2005 Share Posted June 24, 2005 I just came across this when i was joblessly browsing through suprastore: http://www.suprastore.com/gremul.html Link to comment Share on other sites More sharing options...
Gamer Posted June 25, 2005 Share Posted June 25, 2005 Sounds interesting Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 I've spotted that... Apparently the black unit has nice features on it... Doubt very much it will be similar to the blue, such a pity... would be nice to shoehorn on the firmware onto a blue unit, like you can with the gold. Gav Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 I do like the AF target map... will make tuning a lot easier.... Now all we do is get one somehow... Gav Link to comment Share on other sites More sharing options...
adi2009 Posted June 25, 2005 Author Share Posted June 25, 2005 I'm surprised that only Titanmotorsports and Suprastore carry the unit now. ANyways, guess we ll have to wait and see for someone to get it and try it out!!! Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 More here http://www.mohdparts.com/emanage/tmp/ultimate_emanage/index.html Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Well, I've ordered one, so lets see how it goes.... Gav Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 I think Chis won't be far behind with his order too...though I want to see the full feature list before I do anything. It still doesn't officially support 1997.8+ Supra's (VVTi's) Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Yeah, but does it support the Aristo?? Gav Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 Hmmm yes it does...how odd... Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 There we go then.... should do the VVTi on a supra without any problems since they share the same engine... When I spoke to Greddy (Trust) in the US, they said use aristo and they would be happy with it, altho still not 100% supported Gav Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 アリスト JZS161 97.8~ 2JZ-GTE JZS147 91.9~97.7 2JZ-GTE Which in my rough jap is the aristo version...... Gav Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 If anyone can find a definitive list of the features in it then please post them up. This could be very good news for those of us that would love to use a standalone but can't quite stretch to it. Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 Okay, this is what I've worked out so far.. features include Airflow Adjustment Map Airflow output map Injector adjustment map Acceleration injector map Acceleration ignition map Aux output setting - (On / Off) I assume for watercooling NVCS map - VTEC stuff (perhaps could be used for VVTI) Vehicle speed adjusment map Revlimiter map A/F target map - For use with a wideband O2 sensor Analouge output setting - For use with fly by wire throttle Has 2 outputs/inputs Boost sensor input Wires into the ignition to provide advance and retard Wires into the injectors to provide control of the injector length pulse (both shortening and lenghtening unlike the blue/gold units) TPS Connection MAF Sensor Connection MAP Sensor Connection (Can be used for boost cut on the vvti to clamp it) So far that is what I've managed to ascertain.. Gav Link to comment Share on other sites More sharing options...
adi2009 Posted June 25, 2005 Author Share Posted June 25, 2005 Gav, i didnt think you'd go for it already!!! Yeah, but does it support the Aristo?? Gav The only possible thing that might not allow it to be used on the aristo is its wiring loom. i m using an aristo engine is my NA-TT swap but with the supra TT wiring loom ofcourse. Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 The fact that you can have a target AFR map really appeals to me, means my base map can be fairly rough and it will correct the map for me... Also I want to try the iVTEC feature which I'm going to have a go linking into the VVTi.. And then there is the water injection (but I can do that with the blue/gold version anyway). Gav Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 The VVTi is very different to VTEC...personally I wouldn't attempt it if it says VTEC only. If it states it can run VVTi then fair enough but the 2 systems are NOT compatible. And quite honestly you dont need control of it really...unless you go for cams in which case you'd have the VALCON controller instead. Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 iVTEC is very similar in design to VVTi, and is not like the original VTEC in that it has variable positioning..... I want to get the car running smoothly first before I use that canof advanced stuff anyway... Gav Link to comment Share on other sites More sharing options...
adi2009 Posted June 25, 2005 Author Share Posted June 25, 2005 So does having 'Target AFRs' mean that someone with very basic knowlegde about tuning can set it up and have it running? Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 That is my assumption as well.... Gav Link to comment Share on other sites More sharing options...
adi2009 Posted June 25, 2005 Author Share Posted June 25, 2005 Would really like to see what Ian thinks about this unit. Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 To have a target AFR map means it must hook into a WB02 sensor...this is a good thing...what I really want to know is if it has a better Anti Stall feature for use with MAF's and atmos bovs Link to comment Share on other sites More sharing options...
JustGav Posted June 25, 2005 Share Posted June 25, 2005 The anti-stall I'm hoping is to what they now refer to as the Aux Output, since it appears to be a clamp of sorts by the looks of it... Gav Link to comment Share on other sites More sharing options...
Alex Posted June 25, 2005 Share Posted June 25, 2005 A limiting clamp would be superb....but a voltage fixer again will do my skull in!!! Link to comment Share on other sites More sharing options...
Nic Posted June 26, 2005 Share Posted June 26, 2005 I've just checked price and availability of the Greddy E-manage Ultimate here, my supplier has stock and price would be £292 plus postage. If anyone wants one give me a shout. Link to comment Share on other sites More sharing options...
