Greddy E-manage Ultimate *new*
adi2009
Okay, this is what I've worked out so far..
features include
Airflow Adjustment Map
Airflow output map
Injector adjustment map
Acceleration injector map
Acceleration ignition map
Aux output setting - (On / Off) I assume for watercooling
NVCS map - VTEC stuff (perhaps could be used for VVTI)
Vehicle speed adjusment map
Revlimiter map
A/F target map - For use with a wideband O2 sensor
Analouge output setting - For use with fly by wire throttle
Has 2 outputs/inputs
Boost sensor input
Wires into the ignition to provide advance and retard
Wires into the injectors to provide control of the injector length pulse (both shortening and lenghtening unlike the blue/gold units)
TPS Connection
MAF Sensor Connection
MAP Sensor Connection (Can be used for boost cut on the vvti to clamp it)
So far that is what I've managed to ascertain..
Gav
Gav, i didnt think you'd go for it already!!!
Yeah, but does it support the Aristo??
Gav
The only possible thing that might not allow it to be used on the aristo is its wiring loom. i m using an aristo engine is my NA-TT swap but with the supra TT wiring loom ofcourse.
The fact that you can have a target AFR map really appeals to me, means my base map can be fairly rough and it will correct the map for me...
Also I want to try the iVTEC feature which I'm going to have a go linking into the VVTi..
And then there is the water injection (but I can do that with the blue/gold version anyway).
Gav
The VVTi is very different to VTEC...personally I wouldn't attempt it if it says VTEC only. If it states it can run VVTi then fair enough but the 2 systems are NOT compatible. And quite honestly you dont need control of it really...unless you go for cams in which case you'd have the VALCON controller instead.
