Low house water pressure......pressure washer?
DamanC
I have recently moved house only to find the water pressure is pretty poor. I have has slashes with more pressure :)
The outside tap pressure is simply not enough to rinse the supe after a good scrub. I have been thinking of a pressure washer lately anyway, so would one not only aid in the cleaning process but up my cleaning water pressure?
Do they fill up a tank and then fire the tank water out?
Any Recommendations?
AFAIK, from disassembling my Bosch one, its just a pump that ramps up the pressure from the tap/hose feed. There was no storage tank other than the one for adding detergents.
Any modern pressure washer should do, you don't want uber pressure that will strip off the paint though.
Wasn't someone on here selling foam-lances too, or something?
