Crank Signal for HKS FCon Pro......
Suprash
Yes you can
Done this already but on a Syvecs
Will be just the same with a fcon.... remember when wiring in the coil outputs on the fcon to do them in the firing order of the engine.
Only downside to doing it this way is you can get abit of timing difference with ignition timing at high rpm due to the belt stretching on the cam belt.
Ryan
