My Compression test results
Jake
  • Replies 61
Posted Images
Sorry to hear of your problems Jake
Before you start ripping it apart, it may be worth getting someone to borescope it.
It will give you a good idea of any damage without having a million pieces lying around your garage.
Hope you get it sorted soon (and you CJ)
I was thinking about that Gordon. If an endoscope can confirm that there is piston/bore damage (and there very likely is) the engine will have to come out so there's no point me struggling to get the head off in situ.
How do I find someone with an endoscope who can come to me? I could look up "Endoscopy" in the yellow pages but I don't think I'll have much luck there.
I would say without a doubt pull the engine. I have found it way quicker to get to short block with it out (and more knuckle skin left intact!) With those compression readings and plug condition, you will almost certainly have major piston/valve damage. Feel for you mate.
... If an endoscope can confirm that there is piston/bore damage (and there very likely is) the engine will have to come out so there's no point me struggling to get the head off in situ..
A leakdown test can also confirm if the block has to come out.
Not too hard to do, provided that you have an air compressor and the gizmo (you can DIY it or get one from the internet, less than £80 if you look around). You can still turn the engine by hand right?
Correct me if I'm wrong but a leakdown test would fail if a valve was damaged/leaking, wouldn't it?
I did look into how to do a leakdown test but it mentioned using 70bar pressure (seventy bar! Sod that) I do have a compressor but not a 70 bar one, who does! Where can I get this gizmo you mention?
Yes, the engine turns over fine.
Anyway, I did a compression test and cylinder #2 showed 0 psi. What more would a leakdown test tell me?
Thanks
What do you mean by 'fail'?
A leaky valve would have air rushing through it and you'd know immediately mate. You'd even know if it's an intake or exh valve of that cylinder.
Nobody, 100psi is the norm for leakdown tests.
If your compressor outputs 100psi and the cylinder can only hold 90psi, then we say that you've got 10% leak. You don't even care about that, you just want to see where the air goes
I had found one for £60odd a few months ago ("Lawson HIS" I think was the internet shop, not sure though)
You could even make one yourself, I've got a guide on my website. I made one for less than £20
You need to turn the engine bit by bit until each cylinder is at TDC (of compression). Then you pressurise that cylinder. You may need someone to hold the rachet though, as the piston might want to move downwards turning the engine.
It would tell you WHY
if you get bubbles in the coolant, you know
if you get air from the sump, you also know
hissing from the intake or exhaust --- you also know ;)
I don't understand how I could tell *where* the escaping air is going. Isn't a leakdown test not just pressurizing the cylinder and seeing how quickly the pressure drops? How can I tell if it's leaking past a valve or a hole in the piston or whatever? Please explain.
I borrowed an endoscope today. The two pistons with the dodgy compression appear to be intact although the one with no compression at all has two marks in the top of it. I've seen a lot worse though.
Would I be right in thinking an exploratory probe with a telescopic magnet would be an idea? If it brings out bits of piston you know you are in trouble.
If it's the HG it's a head off job, if it's pistons you still need the head off, I'd crack on with taking it off :( It's the only way you'll know for sure.
When mine let go all those years ago, the tops of the pistons looked OK but the edges had eroded away like a lollipop, might not be visible from a borescope exam. Also, my hybrids survived 100% intact, so all is not yet lost on the tubbie front. I guess you'll be taking them off to get at the head anyway, so that's Shit Job No1 on the MkIV you'll soon have under your belt. I'd start putting WD40 on the manifold bolts now :)
Drop me a line if you want to chat about this offline mate.
-Ian
A leakdown test will show where the compression is escaping, if it's a bad leak by being audible down the exhaust if it's an exhaust valve seat problem, out the intake with the throttle wedged open if it's an intake valve leak, and up the dipstick tube or crankacase breather if it's ring or piston failure. Simple ;)
Pistons aren't made of ferrous meterial though.... are they? :conf:
-Ian
He really will be in trouble if he's using magnetic pistons! Cast iron ones? Hewn from steel billet? :D
yep, I thought it would be obvious enough Jake.
You see bubbles up the coolant tank, or hissing from the sump or the intake or the exhaust. You get a pretty good idea what doesn't seal ;)
Haha I had no idea if the stuff was magnetic or not, metallurgy isn't my bag :) That's why I said "would I be right..."
Personally I'd have tried it and gone "hmmm, guess they aren't magnetic then". I refuse to feel foolish as I've learnt something new ;)
-Ian
... I refuse to feel foolish as I've learnt something new ;)
-Ian
Quite right, if we wanted to look and feel foolish they we'd have joined a comedy club, I guess.
I see this as a meeting place where we exchange information and learn from each other.
The only foolish thing for someone would be to avoid asking and make the wrong assumptions later. :)
Mig and I once had a half drunken conversation about using the head as an electromagnet and using it to create a force on the pistons.... we were chatting about it for quite a while I seem to remember, but unfortunately was lashed so can't remember much of what we were saying.
As for aluminium, Everything is magnetic to some degree - even people! ;)
