ManwithSupra Posted February 19, 2011 Share Posted February 19, 2011 I cant tell if its the Belt tensioner, PAS pump or Air con pump... anyone heard this sound before? orItD4806E4 Link to comment Share on other sites More sharing options...
nasoup Posted February 19, 2011 Share Posted February 19, 2011 Try this dude http://www.mkivsupra.net/vbb/showthread.php?233891-Squeaking-noise&highlight=pully+noise Link to comment Share on other sites More sharing options...
Nic Posted February 20, 2011 Share Posted February 20, 2011 It could be the crank pulley has delaminated and the outer ring is slipping. To check if this is the case, use Tipex or something similar to paint a straight line from the centre of the pulley to the outer ring. Run the engine and blip the throttle so you get the squealing noise, turn engine off then inspect the pulley, if the line you painted doesn't line up then the pulley is kaput and needs replacing. Link to comment Share on other sites More sharing options...
ManwithSupra Posted February 20, 2011 Author Share Posted February 20, 2011 It could be the crank pulley has delaminated and the outer ring is slipping. To check if this is the case, use Tipex or something similar to paint a straight line from the centre of the pulley to the outer ring. Run the engine and blip the throttle so you get the squealing noise, turn engine off then inspect the pulley, if the line you painted doesn't line up then the pulley is kaput and needs replacing. Yeah i would have thought that too, however i had the crack pully replaced only a few thousand miles ago (be it a couple of years now). I will check anyway just in case, as until recently i have found out the "recommended" garage that i had been using to service and repair my supra was for a better word crap... i.e not doing a very good Job if at all. Link to comment Share on other sites More sharing options...
Dnk Posted February 20, 2011 Share Posted February 20, 2011 I'd be worried if your recommended garage actually changed it if their as good as you say Link to comment Share on other sites More sharing options...
