Dazzi Posted February 19, 2011 Share Posted February 19, 2011 After a JSPEC TT Exhaust gasket which sits between turbos downpipe and 1st cat Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 19, 2011 Share Posted February 19, 2011 They use a composite metal O ring as stock, I have some perfectly usable new ones. If you have aftermarket stuff fitted these probably won't do, they are just for stock systems. Link to comment Share on other sites More sharing options...
Dazzi Posted February 20, 2011 Author Share Posted February 20, 2011 Yea its aftermarket Chris. Link to comment Share on other sites More sharing options...
Dazzi Posted February 21, 2011 Author Share Posted February 21, 2011 Woops just realised i was asking for the wrong gasket. Im after the 3 hole gasket that fits between the turbos downpipe and 1st cat. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 21, 2011 Share Posted February 21, 2011 I am still unsure what you need. as stock the three studded turbo elbow casting seals to a stock first cat with a metal O ring. If you fit a de cat pipe you bin the O ring, clean the mating surfaces thoroughly, and use a smear of high temperature exhaust sealing paste instead of a gasket. If you are using an aftermarket 1st cat i would need to see a GOOD photo of the mating flange on it. Link to comment Share on other sites More sharing options...
