Andrew Dunk Shaw Posted January 7, 2003 Share Posted January 7, 2003 Hi guys, My heater in my uk mkiv has started playing up, any ideas ? You can turn the temp control knob down and it gets cold but when turned up to the max it doesn't get anywhere near as hot as it used to, it gets warm but thats about it, haveing had a little look cant see anything obvious, the engine temp is spot on as normal, no water leaks anywhere, water system seems fine no air locks or gurgleing noises from dash. Is there some kind of control unit that could have started playing up. Help please as its toooo bloody cold with a lame heater. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted January 7, 2003 Share Posted January 7, 2003 Andrew, there is another thread running about this mate. Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 7, 2003 Share Posted January 7, 2003 Try heater/air con diagnostic codes. Quote Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted January 7, 2003 Author Share Posted January 7, 2003 Originally posted by Terry S Andrew, there is another thread running about this mate. Yes, sorry guys im not really very with it today. Quote Link to comment Share on other sites More sharing options...
womble Posted January 7, 2003 Share Posted January 7, 2003 Andrew, sounds like you also have the same problem as I did, follow the procedure as listed and it should sort out the problem. Trust me it's one of the most satisfying fix's I've ever carried out on a car, it made a massive difference. Before After:flame Dev . Quote Link to comment Share on other sites More sharing options...
