Lots of parts
EMPEROR
I've decided to combine all the threads for the parts I need in one. There will be parts added here now and then and the first post will be updated whenever I need something more.
So parts I need at the moment:
-TT VVTi lower and upper radiator hoses (might be aftermarket)
-TT VVTi upper radiator hose clip (attached to the engine cover)
-trac switch with snow/off + wiring
-Blitz Nur Spec R for TT (it's 80mm piping, NA one is 70mm)
-VVTi or nonVVTi TT engine wiring harness (might be damaged or cut beyond repair, I don't care)
-VVTi TT throttle cable
-TT VVTi TPS sensor
-Supra VVTi TT ECU - 89661-14830 or 89661-14820
-TT fusebox (preferably from VVTi)
-VVTi TT engine bay harness (again might be damaged or cut)
-TT upper and lower fusexbox connectors (I need both the plug and the mating one)
-VVTi TT capacitor (ignition) plug (or if anyone can tell me the exact plug number I will be really thankful)
-TT steering reservoir
-valve air-control - 17630-70020
Please send any offers on PM.
Regards,
Lacho
