johnd-mkiv Posted February 16, 2011 Share Posted February 16, 2011 having some misfire problems with my car at the moment have replaced the plugs an coil packs but still the same need to check the ignition amps not faulty john Link to comment Share on other sites More sharing options...
Swampy442 Posted February 16, 2011 Share Posted February 16, 2011 Amp as in ignitor unit? If so you can borrow mine My car is going nowhere any time soon Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 17, 2011 Share Posted February 17, 2011 You can use two Bosch three channel units if you want something easily available. Skyline igniters are unreliable and VERY VERY expensive, after two failures I have binned them and use Bosch units now, plus they will take more coil dwell without getting hot and bothered. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 17, 2011 Author Share Posted February 17, 2011 Amp as in ignitor unit? If so you can borrow mine My car is going nowhere any time soon Thats the one if you dont mind mate would be greatly appreciated Cheers Chris going to try a working one just to make sure first Link to comment Share on other sites More sharing options...
Swampy442 Posted February 18, 2011 Share Posted February 18, 2011 I do actually have an ignitor that has a channel down so it does happen. PM me your address and Ill get it posted to you. Link to comment Share on other sites More sharing options...
