ray007 Posted February 15, 2011 Share Posted February 15, 2011 Hi all Anyone know if a prop from a mk3 supra r154 would fit onto a soarer r154 gearbox? I have a soarer r154 and having great difficulty fnding a prop so any advice to get around it would be much appreciated Regards Ray Quote Link to comment Share on other sites More sharing options...
steve spedd Posted February 15, 2011 Share Posted February 15, 2011 As far as I'm aware you need the prop off a mkiv supra and the mkiii prop mating together. Swampy is your man for this info. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 15, 2011 Share Posted February 15, 2011 Hi Yes you can use the front section of the MK3 prop and bolt it to the rear section of the Mk4 prop. You will probably have to extend it though Quote Link to comment Share on other sites More sharing options...
ray007 Posted February 15, 2011 Author Share Posted February 15, 2011 Hi Yes you can use the front section of the MK3 prop and bolt it to the rear section of the Mk4 prop. You will probably have to extend it though Thanks buddy But the question I'm asking is that i have a r154 from a soarer and know someone selling a prop from a mk3 supra. So will the front section of the mk3 prop fit an r154 from a soarer? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 15, 2011 Share Posted February 15, 2011 If its from the manual Mk3 turbo then yes, its intrinsically the same box, same input and output shafts, spline numbers etc only the rear casings with the shifters differ. Quote Link to comment Share on other sites More sharing options...
ray007 Posted February 15, 2011 Author Share Posted February 15, 2011 If its from the manual Mk3 turbo then yes, its intrinsically the same box, same input and output shafts, spline numbers etc only the rear casings with the shifters differ. Excellent... Someone is offering the prop £30 delivered, I guess that's a decent price then Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 16, 2011 Share Posted February 16, 2011 Reco-Prop will modify it to suitas required, and balance it, great company, excellent work. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 16, 2011 Share Posted February 16, 2011 Would they need the whole prop to balance it Chris, or just the front section thats been extended? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 16, 2011 Share Posted February 16, 2011 They'd need the whole thing to dynamically balance it properly. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 16, 2011 Share Posted February 16, 2011 Thats what I thought, cheers Quote Link to comment Share on other sites More sharing options...
