Dim Sum Posted February 15, 2011 Share Posted February 15, 2011 Has mentioned on the title could anyone tell me what size break disc for JSpec Facelift N/A? I have the 6speed and big brake setup, will i need to get the biggest size or is it 307mm? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 16, 2011 Share Posted February 16, 2011 Has mentioned on the title could anyone tell me what size break disc for JSpec Facelift N/A? I have the 6speed and big brake setup, will i need to get the biggest size or is it 307mm? You have the UK brakes correct? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 16, 2011 Author Share Posted February 16, 2011 You have the UK brakes correct? yes Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 16, 2011 Share Posted February 16, 2011 323mm front I believe Quote Link to comment Share on other sites More sharing options...
Nic Posted February 16, 2011 Share Posted February 16, 2011 These are the part numbers for the larger brake discs. 43512-14200 & 43516-14030 Toyota Brake Disc - Front 323mm x 30mm 42431-14150 Toyota Brake Disc - Rear 324mm x 16mm Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 16, 2011 Author Share Posted February 16, 2011 323mm front I believe These are the part numbers for the larger brake discs. 43512-14200 & 43516-14030 Toyota Brake Disc - Front 323mm x 30mm 42431-14150 Toyota Brake Disc - Rear 324mm x 16mm Thank you:) 324mm Rear Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 16, 2011 Share Posted February 16, 2011 All listed on my website here if needed. All in stock as well. Quote Link to comment Share on other sites More sharing options...
