JohnA Posted June 24, 2005 Share Posted June 24, 2005 I've just managed to cripple my IACV VSV (as said in other thread) and ordered a new one through "T" . Trouble is that the part number from their catalog came out as 25860-46060. The old part itself has "90910-12126-B" stamped on it. WTF? Anybody can check on these two numbers please? My version of EPC still doesn't play ball with *any* of the 4 PCs I've got at home PS brittle little thingie, it's on top of a very hot engine, with hot pressurised gases passing through it. Why the hell did they make it out of plastic? What were they thinking? I just tried to pull out the hose and it sheared off. It's not gonna do the turbo#2 any favours if it hits 4Krpm, the ECV opens and the intake stays shut. Worst case the overwhelmed reed valve breaks apart and showers the cylinders with debris. Niiiiice... Quote Link to comment Share on other sites More sharing options...
colsoop Posted June 24, 2005 Share Posted June 24, 2005 A ha thats where that little part lives According to that part no this is what you get (see attached) looks like the doobery to me could you update me on the cost of it please Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 24, 2005 Author Share Posted June 24, 2005 yep, 25860 is the ref in that diagram, same as Toyota had. What part number do you get for that little fella? Quote Link to comment Share on other sites More sharing options...
colsoop Posted June 24, 2005 Share Posted June 24, 2005 I did a search with the part number you posted up (25860-46060) and that is the part that came up in the EPC. If you see what i mean Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 24, 2005 Author Share Posted June 24, 2005 So why on earth does the part have a different (valid Toyota) number printed on it?!!? Quote Link to comment Share on other sites More sharing options...
colsoop Posted June 24, 2005 Share Posted June 24, 2005 Do you mean the 90910 12 126-b bit on the side ? I have no idea Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 24, 2005 Share Posted June 24, 2005 Sometimes OEMs will change the number if they have a small change done to the item, such as internal cost saving on parts etc. It is normally to help the supplier of the part to Toyota, we change part numbers on their items for some things like adding a small cut to the front edge (for rain sensor harness). It is the same part, but a newer revision, if you get what I mean. Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 24, 2005 Share Posted June 24, 2005 Do you mean the 90910 12 126-b bit on the side ? I have no idea I've just noticed the "b" reference, which is a little strange, as Toyota usually have the letter reference for different colours, which wouldn't apply to that specific part. Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 24, 2005 Author Share Posted June 24, 2005 The trouble is that Toyta refuse to refund for 'special orders' which is practically any such part for the Supra. So if I compare the part on Tuesday and it looks nothing like the original one, I'm stuck with it. £50 odd quid worse off, too. What also makes me think is the wisdom of using plastic parts in such hot areas. If this flimsy plastic nipple cracks or breaks (which it did) then the IACV won't open when it should (boost pressure won't be directed to the back of the IACV actuator) and it's a matter of time when you'll say goodbye to turbo#2. ...and what's the idea of directing boost gases taken before the i/c? It would have been better for the designers to feed the pressure tank after the i/c and adjust the actuator springs accordingly (as cooler air has lower pressure). 100C pressurised air through plastic bits and rubber hoses is not my idea of reliability. [/rant] Quote Link to comment Share on other sites More sharing options...
jamesgtr Posted June 25, 2005 Share Posted June 25, 2005 could you update me on the cost of it please 25860-46060 retail 43.06 + vat btw, part numbers stamped on oe part not always applicable when ordering. Quote Link to comment Share on other sites More sharing options...
Miguel Posted June 25, 2005 Share Posted June 25, 2005 Or if you fancy I'm sure all the bods that have gone single will have that VSV for sale if you did not fancy splashing out 50 note's...worth an ask ? Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 25, 2005 Author Share Posted June 25, 2005 I *did* think of all the VSV leftovers from the people who've gone single, yes. But 1. The car is almost wounded in the meantime (stuck to below 4K) and these searches take time. 2. The used VSV would be brittle just like the old one, wouldn't it? Sitting on top of the engine, what other chances does it have? So is it worth waiting longer for something that is potentially weaker, just to save £10-20? Since the life of turbo#2 depends on this part, I thought not. Quote Link to comment Share on other sites More sharing options...
Miguel Posted June 25, 2005 Share Posted June 25, 2005 TBH all the ones I have pulled off for singles have been in perfect working order. Only one has been brittle to date ...but they all went back to the customers ...just a thought thats all ..And they may just give them to you ..so it would save you more than a tenner if you ask nice ...there are loads on here. like I say only a thought so ill shut up now . Quote Link to comment Share on other sites More sharing options...
