nevins Posted February 14, 2011 Share Posted February 14, 2011 Right then guys need some help with this. Craig just rang me with a problem. He is stripping down his garrett turbo to do a gasket, but the core is stuck in the not side housing. All the bolts are out but it is stuck tight. He as tried tapping the housing when someone pulls but its not having any of it. Has anyone had this problem before and if so how did you get it free. Thanks Gareth Quote Link to comment Share on other sites More sharing options...
nevins Posted February 14, 2011 Author Share Posted February 14, 2011 Anyone, we really need this off tonight. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 14, 2011 Share Posted February 14, 2011 Umm loads of GT85 and some brute force? Theres no way you can use a puller I suppose. Quote Link to comment Share on other sites More sharing options...
nevins Posted February 14, 2011 Author Share Posted February 14, 2011 Not really to be honest. How safe is it to hit with a twatandfelter Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 14, 2011 Share Posted February 14, 2011 Is it on the car or removed? Sure if you cover the oil ports and put the cartridge in some soft jaws in a vice and tapped the exhaust housing that should free it off? Quote Link to comment Share on other sites More sharing options...
nevins Posted February 14, 2011 Author Share Posted February 14, 2011 Will let him know, im sure he said its on the car as he can not get at one of the bolts, bare in mind this is a n/a-t so a bit tighter to work on Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted February 14, 2011 Share Posted February 14, 2011 I take it you have had a look online to see if anyone has had the problem elsewhere? I have had a look but being a noob, i dont know exactly what im looking for =/ Quote Link to comment Share on other sites More sharing options...
nevins Posted February 14, 2011 Author Share Posted February 14, 2011 First thing that was done mate. Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted February 14, 2011 Share Posted February 14, 2011 Ahh thought as much.. last resort.. lots of heat and BFI? Quote Link to comment Share on other sites More sharing options...
nevins Posted February 14, 2011 Author Share Posted February 14, 2011 don't want to go to mad with it in case the turbo gets damaged Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted February 14, 2011 Share Posted February 14, 2011 As you say dude.. no need to go too mad. turbos heat up a hell of a lot. might just need it to help it out. not that i would be brave enough to do it >. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 14, 2011 Share Posted February 14, 2011 cheers nev, just a bit more info, to remove the turbo the cor has to be removed befor i can access the 2 rear bolts. i have been hours tapping spraying and pulling and the bugger is really tigt , it will not budge. i even resorted to a mallet and a chissel in my anger and it will not open , its flat out rediculous. any tips would be greatly recived Quote Link to comment Share on other sites More sharing options...
nevins Posted February 14, 2011 Author Share Posted February 14, 2011 I will be down wednesday after dropping sam off to work and will get to work on the supra mate. Also going to be attacking it for weight saving to. Quote Link to comment Share on other sites More sharing options...
SimonB Posted February 15, 2011 Share Posted February 15, 2011 It can be a total nightmare to get the hot side housings off the turbo, they are an interference fit and once they have been on for a while don't want to come off! I remember having a real struggle with my T67 when I was changing the housing for a larger A/R one. Can't remember how I got it off in the end, sorry! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 15, 2011 Share Posted February 15, 2011 lol cheers, i think im going to give up on this as i vant see a way of splitting it without damaging it Quote Link to comment Share on other sites More sharing options...
edge Posted February 15, 2011 Share Posted February 15, 2011 Did you try a heat gun on it or ideally a gas torch of types? If not do you know any welders that could weld something on it to get some leverage but i'm not sure if welding could damage it Quote Link to comment Share on other sites More sharing options...
