imi Posted February 14, 2011 Share Posted February 14, 2011 Hi all Have the following Oil Temp and Oil Pressure probe to fit the car this week, need some help in getting the right sized parts for these to bolt into. Oil Temp - M12 x 1.5mm Oil Pressure port thread 3/8" x 24 UNF male OPTION 1 Facelift Union Bolt for the Oil pressure AND Oil Sump Plug Adaptor - will this one fit fine? OPTION 2 Sandwich plate for both to connect into, would this one be the right one to go for? help appreciated. imi Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 14, 2011 Share Posted February 14, 2011 Definitely option 1 mate. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2011 Share Posted February 14, 2011 What does the probe look like? My car is low and there are speedbumps around, does it hang out the bottom of the sump? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 14, 2011 Share Posted February 14, 2011 What does the probe look like? My car is low and there are speedbumps around, does it hang out the bottom of the sump? Good point! i actually welded a boss into the side of my sump to avoid any problem with that, but others seem to be OK with sump plug adapters. Quote Link to comment Share on other sites More sharing options...
Wez Posted February 14, 2011 Share Posted February 14, 2011 Good question, the option 1 facelift bolt sounds like a good bet, not sure about the sump plug though. Is the sump the best place to measure oil temp? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 14, 2011 Share Posted February 14, 2011 Good question, the option 1 facelift bolt sounds like a good bet, not sure about the sump plug though. Is the sump the best place to measure oil temp? I always thought so, as its a more stable temp and so reflects a realistic average, rather than peaks, as a sandwich plate or bolt adapter will supply, as the oil in this location will pick up heat transfer from the combustion chamber due to the small oil galleries. Quote Link to comment Share on other sites More sharing options...
imi Posted February 14, 2011 Author Share Posted February 14, 2011 Good question, the option 1 facelift bolt sounds like a good bet, not sure about the sump plug though. Is the sump the best place to measure oil temp? Not sure about best but CW believes its perfectly fine thread here http://www.mkivsupra.net/vbb/showthread.php?237300-Oil-Sandwich-Plate I will go with a Lee supplied Blitz sandwich plate that he will get tapped for the sensors that I have. thanks LeeP. Quote Link to comment Share on other sites More sharing options...
