ABS Warning Light
jevansio
My ABS light came on the other day, I was experiencing a missfire at the time, so I unplugged the RLTC from the loom and the missfire went away, so did the ABS fault.
Anyway, the ABS light has come back on (and the RLTC is still disconnected), I checked the error codes, I got 31, 41, 49, 51 & 71.
Could this be due to a faulty battery, I left my interior light on a couple of weeks ago and the battery drained. I recharged it and everything seemed fine, but i know these small Redtops don't like full discharges?
I'm guessing a plethora of faults like that has to be something fundamental, even though 2 of the faults are on the FR wheel speed sensor?
I'd try disconnecting the battery to reset the ECU, driving around a bit and then rechecking for any stored fault codes.
Already done that, tried a big battery too (my original one I use whenever I need to rule out the Varley). Both batteries show 12v on the volmeter and start the car fine.
You can discount 31 and 41. Those are map sensor and TPS. You will always have them cos your not running a stock MAP sensor and you will have a sub TPS with reverse wiring on the TB cos it's a Q45.
I finish work at 12am I'll give you a call.
These are the ABS codes bud, they are:
Code 31 - On/Off/On
Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector.
Code 41 - On/Off/On
Battery voltage is abnormally high or low. Check battery and
voltage regulator.
Code 49 ???
Code 51 - On/Off/On
Actuator pump motor is locked or pump motor circuit is open.
Check pump motor, pump motor relay, vehicle battery, actuator wiring
harness, connectors, actuator pump motor circuit, and actuator ground
bolt.
Code 71
Low voltage of right front speed sensor signal. Inspect right front speed sensor and sensor installation.
Cheers mate, I'll be down the club but I will take my phone :)
OK, I reset the ABS codes, and took the car out for a drive. The ABS light was off. There was still an ABS problem though, when I pulled up to junctions etc the ABS kicked in even with soft braking. I took the car upto 60mph and did a harsh stop, the car pulled to the left as if no braking was going to the right front wheel. Then the ABS warning came back on and the brakes went normal as if the ABS had been disabled. The ECU had the errors back.
I'm going to plug the RLTC back in so I can monitor the speed sensors (as I don't believe it was the RLTC at fault now, rather an ABS error casuing it to go mad).
Is it worth swapping the ECU? Does anyone have an ABS ECU lying around I can try? I'm going to ditch the ABS in the summer anyway, so as long as the speed sensors are fine I don't really mind if the ABS unit has gone screwy
